Can Sound Waves at 1100Hz Be Received and Emitted Effectively?
Sound waves at 1100Hz can be received and emitted using various devices, including microphones and specialized acoustic analyzers. A microphone connected to a computer with software can isolate this frequency, while analog filters can also achieve similar results. Tuning forks can respond to specific frequencies, and a simple op-amp circuit can amplify signals at 1100Hz, triggering an LED when a certain threshold is exceeded. Handheld acoustic analyzers provide customizable displays for frequency detection. Overall, there are effective methods and devices available for detecting and displaying sound waves at 1100Hz.
callumbrad128
Hopefully i am not wasting anyones time, as i don't know a lot about sound waves etc.. but i was wondering if anyone could help. Is there such a thing that receives sound waves of around 1100hz. maybe a sound receiver and emmitter? I have tried finding as much infomation online, but there is limited results. I know this may not be the 'normal type of question' but any info would help massively.
Your ear, a microphone, a brick wall?
Every object receives sound waves that reach it - not all of them do anything except absorb them.
Do you want to detect 1100hz sound, detect only this frequency, block only this frequency or what?
Sorry, there was no clarity in what I was asking! But yer basically Is there a device that only picks up this frequency/only picks up this frequency and above! And displays in whichever means possible(a gragh, by a light bulb, etc...) if this frequency is heard!
A tuning fork would respond to only one frequency (or at least a narrow band of frequencies )
The easiest way is a microphone and either a computer and some software to pull out just that one frequency, or you can do it with an analog electronics filter.
This is what the graphic equiliser on a hifi does.
Many hand held acoustic analyzers will do what you are looking for as well. They will pick up all frequencies up to a certain limit and will have customizable displays that you can tailor to whatever you are looking for.
Hello Callumbrad-
Here in thumbnail is a simple 1-opamp tuned narrowband amplifier that can be used with a microphone [STRIKE]or loudspeaker[/STRIKE] input. Voltage source V2 in circuit is a 1-millivolt signal that is swept from 500 Hz to 2000 Hz. The output signal is maximim at 1100 Hz, with an amplitude of 200 millivolts.
[added] It is straight forward to ad an op-amp that lights a LED if the sound signal level exceeds a threshold at the output of this circuit.
[added2] The LT1014 is equivalent to the LM324.
Bob S
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
