Discover the Spin of an Electron Using Angular Momentum Operator and Eigenvalues
rubertoda
I should Use
the fact that in general the eigenvalues of the square of the angular momentum
operator is J(J + 1)h and show the spin of the electron.
I have J= L+S and J2 = L2+ S2
But how could i find the spin of the electron
Not really, J^2 = L^2 + S^2 +2 L.S. And post the whole text of your problem.
Yes, i was sloppy. I meant that. But, I am asked to show the spin of the electron, by knowing that the eigenvalue of J2 is usually J(J+1)hbar...what do they mean?
sthg like solving for S in J^2 = L^2 + S^2 +2 L.S?
rubertoda said:
Yes, i was sloppy. I meant that. But, I am asked to show the spin of the electron, by knowing that the eigenvalue of J2 is usually J(J+1)hbar2...what do they mean?
So how to do this
Can you, please, post the text of your problem, exactly as it appears in your book ?
Calculate the square of the total spin operator and find all its eigenvalues. Use
operator is J(J + 1)¯h
to find the spin of the electron.
the firts one i have fixed..
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
