Discrepancy in the spring constant using force vs energy
The discussion centers on the discrepancy in calculating the spring constant (k) using two different methods: force equilibrium and energy conservation. When using force, k is derived as k = mg/x, while energy calculations yield k = 2mg/x, indicating a factor of two difference. The error arises from misunderstanding the equilibrium state and the dynamics of the system, particularly the role of kinetic energy during the spring's oscillation. The correct approach involves recognizing that potential energy lost by the weight equals the elastic energy gained by the spring plus the kinetic energy of the weight.
  • Understanding of Hooke's Law and spring mechanics
  • Familiarity with potential and kinetic energy concepts
  • Knowledge of equilibrium conditions in mechanical systems
  • Basic principles of oscillatory motion
  • Study the principles of energy conservation in mechanical systems
  • Learn about oscillations and the dynamics of spring-mass systems
  • Explore the derivation and implications of Hooke's Law
  • Investigate the role of kinetic energy in dynamic systems
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of spring systems and energy conservation principles.
MrRice5555
Lets say you have a spring with unknown constant k. You try to calculate the value of this constant by hanging a known mass m from the spring. The spring stretches until the force of the spring equals the weight of the mass. Thus, kx = mg, and k = mg/x . However, if you try to calculate this same constant using energy instead, by setting the zero point at the lowest point after the spring is stretched, we have an initial potential energy of mgh. Once you release the mass though, the potential energy of gravity converts into potential energy of spring, which is 0.5 kx^2. Setting mgh = 0.5kx^2, we have k = 2mgh / x^2. However, we defined h = x, and the equation reduces to k = 2mg/ x, exactly twice what we calculated using force. I don't understand why this happens, because your answer should be the same no matter how you calculate it. If you can explain what mistake I'm making, that would be very helpful. Thanks!
--Stephen
The force is not zero when the total potential energy is zero. In short, x is not the same in your two methods.
Taking the total potential energy as U = 0.5*k*x^2 + mgx, with x=0 at the equilibrium of the spring by itself. Then the there are two roots of U = 0; x = 0, and x = -2*m*g/k. However, that does not mean the net force is zero. F = -dU/dx = -(kx + mg). At the roots of U=0 you get F = -mg and F = mg, not F=0. The position which F=0 is the position around which the mass will oscillate.
--Stephen
Heh... this is a great paradox! It's kept me up past my bedtime...
The conceptual error is in treating an equilibrium configuration as a process:
At equilibrium the sum of the forces (and torques) is zero; also, the energy is a minimum.
The sum of the forces: kx = mg, k = mg/x,
The minimization of the energy: 1/2kx^2 -mgx = U, dU/dx = 0 -> kx - mg = 0 -> k = mg/x.
Note the sign of mgx- the weight moves down from x = 0.
Here is another explanation.
You are trying to equate the work done by the weight on the spring to the loss of potential energy of the weight.
This is not correct because it is missing a term.
Consider what happens when when you release the weight:
The weight falls gaining kinetic energy. Some of this is transferred to the spring but when the weight reaches the position where the spring return force just balances the gravity force on the weight, the weight is still moving.
So the true energy balance is
Potential Energy lost by weight = Elastic Energy gained by spring + Kinetic energy gained by weight.
This latter lerm leads to the oscillation about the equilibrium position.
  • · Replies 76 ·
