Is there a way to quickly dissolve vegetable plants using acid?
In summary, a client of Jon's landscaping company wants to have a large container filled with a substance that she can throw her unwanted vegetable plants into and have them completely dissolve in the shortest amount of time possible. Concentrated sulfuric acid would probably work well, but a "Piranha solution" composed of hydrogen peroxide and sulfuric acid is even better and will dissolve almost anything. The user requirement is characteristically unpractical; she would do far better with sealable plastic garbage bags, possibly sprinkled periodically with some dry lime, powdered clay, or cat litter.
obx
Urgent: Need Advice/Suggestions
Is there is any type of acid, etc. that would be able to completely dissolve a vegetable plant upon contact, or within say a matter of minutes?
A client of my landscaping company wants to have a large container filled with a substance that she can throw her unwanted vegetable plants into and have them completely dissolve in the shortest amount of time possible, preferably on contact. Any advice, or suggestions would be greatly appreciated.
Thank you.
Chemistry news on Phys.org
Concentrated sulfuric acid would probably work well. A "Piranha solution" composed of hydrogen peroxide and sulfuric acid is even better and will dissolve almost anything.
Note: You need to be extremely careful with these types of solutions. Since they can dissolve the organic matter of plants, they can also dissolve your skin. Please take the necessary precautions and research the proper handling of these chemicals before attempting this.
OBX, Don't listen!
Cesium! YOU GOTTA BE JOKING!
:bugeye:
While you were at it, why not chrome/sulphuric or sulphuric acid/permanganate and REALLY make a job of it?
Nothing of that kind is suitable except for professional chemists or similarly appropriately trained professionals to work with! You want to leave a bucket of the like with folks who probably couldn't even find a suitable container? What about fume control and splashing? The very request is a giveaway; the woman hasn't a clue what she is asking, and would have no idea of the hazards or how to deal with emergencies. (What emergencies, were you going to ask? If so, your own practical chemical expertise could do with a bit of dusting off.)
And how the gyp is she to dispose of the residual crud once it stops working? Besides, chemical solution of such material would be really expensive and wasteful. And smelly too.
The user requirement is characteristically unpractical; she would do far better with sealable plastic garbage bags, possibly sprinkled periodically with some dry lime, powdered clay, or cat litter. Or even consider a dedicated incinerator with an output filter if she insists on instant destruction. Cheaper, safer, cleaner than any reasonable alternative short of a composter or fermenter. :
For a start, does anyone know why she wants it? Tidiness? Disease control? Aesthetics? Unless we know, we cannot give sound advice.
Jon :rolleyes:
Have to deal with heavy metal waste then. Also it's unlikely a nonchemist would have access to these materials.
Concentrated sulfuric acid (98%) is sold in drain cleaners and is something that the general public does, in fact, deal with. One can carefully neutralize H2SO4 with bicarbonate to give harmless sodium sulfate. I'm not saying I'd do it or that one should do it, but he or she is asking a chemistry forum. Clearly, there's no 100% safe way to dissolve organic matter "upon contact."
If the result of the effect of the H2SO4 is not complete oxidation as in a Kjeldahl, the resulting sludge is not likely to be much healthier than a manganese sludge. The Cr might be a bit worse of course.
Point taken, but not with peroxide right? In my book that would count as a pretty sprightly cocktail.:bugeye:
Well gee man! You could have mentioned that to the straight man (or woman) instead of idly remarking that it could be bad for the complexion or YMMV...
So obx, you have been warned: cesium might not do it, I would only do it under exceptional circumstantial duress, and I suspect that in our cooler moments neither of us would enthusiastically recommend it to your friend!
Particularly without knowing the reasoning behind the request, apart from a taste for pyrotechnics or an alkahest.
Cheers,
Jon
1. How does dissolving plant matter work?
Dissolving plant matter involves breaking down the cell walls of plants using a solvent, such as water or alcohol. The solvent penetrates the cell walls and separates the molecules of the plant material, causing it to dissolve.
2. What solvents are commonly used to dissolve plant matter?
The most commonly used solvents for dissolving plant matter are water and alcohol. Other solvents such as acetone and hexane can also be used, but they may not be as effective or safe.
3. What is the purpose of dissolving plant matter?
Dissolving plant matter can be used for various purposes, such as extracting compounds or chemicals from plants for scientific research or creating natural dyes or medicines. It can also be used to break down plant material for easier digestion in animals or in composting.
4. Is dissolving plant matter harmful to the environment?
The impact of dissolving plant matter on the environment depends on the specific solvent used and the amount of plant matter being dissolved. Water and alcohol are generally considered safe for the environment, but other solvents may have more harmful effects. It is important to properly dispose of any solvents used in the process.
5. Can all types of plant matter be dissolved?
Not all types of plant matter can be dissolved, as some have stronger cell walls that are more resistant to solvents. Additionally, some compounds in plants may not be soluble in certain solvents. It is important to research the specific plant material and solvent being used to determine if it can be dissolved.
26K
  • General Discussion
  • Earth Sciences
  • STEM Career Guidance
64K
9K
