Divergence of a cross product help
The discussion revolves around proving the identity for the divergence of a cross product in an arbitrary coordinate system, specifically involving scaling factors. The original poster seeks to establish the identity using the Levi-Civita symbol and is exploring the implications of scaling factors in the proof.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various methods to incorporate scaling factors into the proof, with some suggesting simplifications and the application of the product rule. Questions arise about the nature of the scaling factors and their treatment in derivatives.
There are multiple lines of reasoning being explored, with some participants suggesting alternative approaches to handle the scaling factors. Guidance has been offered regarding the use of fixed variables and the chain rule, but no consensus has been reached on the best method to prove the identity.
Participants note that the scaling factors are functions of coordinates, which adds complexity to the proof. The discussion includes references to curvilinear coordinates and the need for careful handling of derivatives in this context.
simba_lk
I need to prove the identity: [itex]\nabla[/itex]([itex]\vec{A} \times \vec{B}[/itex])=[itex]\vec{B} \bullet[/itex]([itex]\nabla \times \vec{A}[/itex]) - [itex]\vec{A} \bullet[/itex]( [itex]\nabla \times \vec{B}[/itex])
I need to prove for an arbitrary coordinate system, meaning I have scaling factors.
The proof should be quite straight forward if you use the levi chevita symbol but so far this is what i have:
[itex]\nabla[/itex]([itex]\vec{A} \times \vec{B}[/itex])=[itex]\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}[/itex]( [itex]\frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} B_{k}[/itex]) = [itex]\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}[/itex]( [itex]\frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} B_{k}[/itex]) [itex]\ast \hat{e_{i}} \bullet \hat{e_{i}}[/itex]
But I can't see how to take it into the desired format
I think I should squeeze in a kroncker delta somehow, but I'm not sure.
Do you know how to do the proof without the scaling factors?
Yes, I just tried and it works fine even without the addition of unit vectors and the delta.
My problem is that I cannot take the scaling factors in or out of the derivative.
Perhaps I missed somthing?
Would these scaling factors perhaps be constants? Or are they functions of one or more of the coordinates?
Of course they are functions, consider for instance spherical coordinates
I'd try simplifying ##\frac{h_1 h_2 h_3}{h_i}## to ##h_j h_k##. Then I think you just have to apply the product rule and grind it out.
This is my idea too but how can take the scaling factor out of the derivative?
I don't know why you want to fool with h or moving it. Just use the chain rule to hold each vector fixed in turn.
$$\dfrac{\mathrm{d}}{\mathrm{dt}}u=\dfrac{\mathrm{dx}}{\mathrm{dt}}\dfrac{\partial}{\partial x}u+\dfrac{\mathrm{dy}}{\mathrm{dt}} \dfrac{\partial} {\partial y}u$$
in your example
$$\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} B_{k}) =\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} (B_{k})_\mathrm{fixed}) +\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} (A_{j})_\mathrm{fixed} B_{k}) $$
Ok but this doesn't prove the identity, if you look at the definition of the curl in curvilinear coordinates
Once variables are fixed they can move through derivatives and the identity is easily proven
$$\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} B_{k}) =(B_{k})_\mathrm{fixed} \frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} ) +(A_{j})_\mathrm{fixed} \frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} B_{k}) $$
Hint:
$$\nabla\cdot(\vec{A} \times \vec{B})
= \frac{1}{h_1 h_2 h_3} \frac{\partial}{\partial x_i} [h_j h_k \epsilon_{ijk} A_{j} B_{k}]
= \frac{1}{h_1 h_2 h_3} \frac{\partial}{\partial x_i} [\epsilon_{ijk} (h_j A_j) (h_k B_k)]$$
thanks a lot
