Divergence of a position vector in spherical coordinates
24 replies · 6K views
Terrycho
I know the divergence of any position vectors in spherical coordinates is just simply 3, which represents their dimension. But there's a little thing that confuses me.
The vector field of A is written as follows,
A_r      \hat{\mathbf r}     + A_\theta \hat{\boldsymbol \theta} + A_\varphi \hat{\boldsymbol \varphi}
and the divergence of a vector field A in spherical coordinates are written as follows
{1 \over r^2}{\partial \left( r^2 A_r \right) \over \partial r} + {1 \over r\sin\theta}{\partial \over \partial \theta} \left(  A_\theta\sin\theta \right) + {1 \over r\sin\theta}{\partial A_\varphi \over \partial \varphi}
, which shows you have to put terms of A related to theta or psi.
However, when you represent a position using a position vector in spherical coordinates, you usually only use r hat simply because r hat includes angle terms already.
Then, when do you use theta or psi terms? And what exactly do A_theta and A_psi term represent when r hat already has the meaning of angles? I have a feeling that they are redundant.
I heard this is related to something called spherical symmetry but want to understand it strictly. Thanks!
[Moderator's note: Approved as not being homework.]
Terrycho said:
Summary:: I know the divergence of any position vectors in spherical coordinates is just simply 3, which represents their dimension. But there's a little thing that confuses me.
First, a position vector is simply a single vector. You cannot differentiate it or take its divergence. What you can do is define a vector field everywhere with:
$$\vec A(r, \theta, \phi) = \vec r = r \hat r$$
This gives you a vector field that can be differentiated and its divergence is ##3## everywhere. Note also that the divergence of a vector field is a scalar field: i.e. a real-valued function associated with every point.
Now, a vector field can have components in any direction. So, we have in general:
$$\vec A(r, \theta, \phi) = A_r(r, \theta, \phi) \hat r + A_{\theta}(r, \theta, \phi) \hat \theta + A_{\phi}(r, \theta, \phi) \hat \phi $$
In other words, the vector field involves three real-valued functions at each point in space. The field of position vectors is only one example. The divergence of this field is given by the equation you posted.
Thank you! So a vector field can be defined as either $$\vec A(r, \theta, \phi) = \vec r = r \hat r$$ or $$\vec A(r, \theta, \phi) = A_r(r, \theta, \phi) \hat r + A_{\theta}(r, \theta, \phi) \hat \theta + A_{\phi}(r, \theta, \phi) \hat \phi $$. Is that right?
Also then, from my understanding, you can always say that
$$A_r(r, \theta, \phi) \ = r$$
, and
$$A_{\theta}(r, \theta, \phi) = A_{\phi}(r, \theta, \phi)=0$$
is this right as well?
If so, is there any case that you have to write $$A_{\theta}(r, \theta, \phi) and A_{\phi}(r, \theta, \phi)$$ that are not zero?
, and
In principle, ##A_r, A_{\theta}, A_{\phi}## can be any functions you like. For example, the vector field could represent the velocity of a fluid at any point.
Often you use spherical coordinates when you have a spherically symmetric field - that's when it's most useful. E.g. the gravitational field might be:
$$\vec g = -\frac{GM}{r^2}\hat r$$
But, any field can be represented in spherical coordinates if you want.
Any? Even a uniform field? I don't mean to cause trouble, but "any" is too all encompassing without qualifications.
The divergence of the position vector equals three in any coordinate system.
Why not a uniform field? Aside from the coordinate singularity at ##r=0##, it’s just a coordinate transformation, is it not?
Yes, in principle it is "just" a coordinate transformation, I guess. I have no idea though how to proceed to find it. It boggles my mind to imagine how to take ##\vec E=E_0~\hat z## and write it as ##\vec E= E_r(r,\theta,\phi)~\hat r+E_{\theta}(r,\theta,\phi)~\hat \theta+E_{\phi}(r,\theta,\phi)~\hat \phi##. In particular how does one handle the spherical unit vectors the direction of which depends on the spherical angles?
So to let A_θ(r,θ,ϕ)=A_ϕ(r,θ,ϕ)=0, does a field have to be spherically symmetric ,or as you said, you can assign any function?
If you want an exercise, you could calculate the divergence of:
$$\vec A = (r \cos \theta) \hat r + (r \sin \theta) \hat \theta + (r\sin \theta \cos \phi) \hat \phi$$
$$\hat z = \cos \theta \ \hat r - \sin \theta \ \hat \theta$$
Thanks! I guess I was considering some useless stuff haha
Actually, one example is the electric field of a dipole oriented along the z-axis:
$$\vec E = \frac{p}{4\pi \epsilon_0 r^3}(2\cos \theta \ \hat r + \sin \theta \ \hat \theta)$$
Actually, the coordinate singularity is the whole z-axis. So, like the dipole example, we perhaps need the field to be in the ##\hat r## direction on the z-axis, where ##\hat \theta## and ##\hat \phi## are not well defined.
Yes, of course. I tripped over my own feet even though I have taught the conducting sphere in a uniform electric field many times. :headbang: Must be a subtle effect of home confinement.
→A=(rcosθ)^r+(rsinθ)^θ+(rsinθcosϕ)^ϕ
Shouldn't this be →A=(rcosθ)^r+(rsinθsinϕ)^θ+(rsinθcosϕ)^ϕ
Why should it be that?
Sorry and should the unit vectors by x y and z rather than r theta phi
Not in spherical coordinates!
Sorry, I was confused. Not the first time I answered off the cuff. I should read all the responses to the original post before answering. I will try to do this in the future.
I'm a bit puzzled about, what this discussion is about. You want to get the divergence of the vector field
$$\vec{A}(\vec{r})=\vec{r}=r \vec{e}_r.$$
The components in spherical orthonormal coordinates thus are
$$A_r=r, \quad A_{\vartheta}=A_{\varphi}=0.$$
Now you can simply take the formula for the divergence given in #1, which simplifies to
$$\vec{\nabla} \cdot \vec{A} =\frac{1}{r^2} \partial_r (r^2 A_r) = \frac{1}{r^2} \partial_r (r^3)=\frac{1}{r^2} 2 r^2 =3,$$
as it must be.
The divergence of a vector field is a scalar field and thus independent of the choice of coordinates used to calculate it. So it's no surprise to get ##3## as when using Cartesian coordinates.
The original question was whether ##\vec A = \vec r## is the only possible vector field expressible in spherical coordinates.
I think it has been shown that it is not the only one.
"I know the divergence of any position vectors"
If someone gave a definition of "position vector", it could end this thread gracefully.
A position vector is the vector pointing from the origin of the reference frame to the position. Again, it's really simple. In Cartesian coordinates you have ##\vec{r}=x_j \vec{e}_j## (Einstein summation notation used), and the divergence of a vector field is ##\text{div} \vec{A}=\vec{\nabla} \cdot \vec{A}=\partial_j \vec{A}_j##. If ##\vec{A}=\vec{r}## you thus have ##\text{div} \vec{A} = \partial_1 x_1 + \partial_2 x_2 + \partial_3 x_3=3##. Of course you get the same result in any coordinates, because the divergence of a vector field is a scalar and thus independent of the choice of coordinates.
