Altabeh said:
You seem to have forgotten to take a quick peep at your post #7 in this thread: All you said there was that you introduced an scalar but called it inattentively "scalar curvature" and assigned to it the same symbol we use for the "scalar curvature" g^{\mu\nu}R_{\mu\nu} in GR so when I asked for the reason behind defining R in this way, you suggested me to take a look at this http://en.wikipedia.org/wiki/Curvature_invariant_(general_relativity)" where the curvature invariants are discussed briefly without any reference to the fact that all of them use distinctive symbols other than R. So am I given this right to get confused when seeing your posts and misleading notations!?
I am using standard notation.
R_{ab} is used to refer to the Ricci curvature. The curvature scalar I am talking about is, once again,
R^{ab}R_{ab}
which is of course not
R=g^{ab}R_{ab}
the Ricci scalar.
It is clear from the very first line in this thread what curvature scalar I was referring to. It baffles me that you are complaining that I said in post #7 "variation of the curvature scalar" and then I wrote the curvature scalar I was referring to once again ... how can you complain that is unclear even now? Fine, you misunderstood. But I've tried to correct your misunderstanding several times now.
The fact that you are now starting to use "R" to refer to the curvature scalar I was referring to, is only making me worry you still don't understand. Especially since I am using standard tensor notation here. There should be no ambiguity.
There are many curvature scalars. If you need to give this one a name, wikipedia refers to it as "The principal quadratic invariant of the Ricci tensor" in that link I gave you. R^{ab}R_{ab} is unambiguous and shorter.
I hope we have finally settled any notation issues.
Altabeh said:
I think the answer I gave in an early post gets everything straight:
Anyways, if the math is seamless, why not? We can admit a new field equation with a new curvature invariant as once Einstein published his own and we read it and started to believe in it! But there are so many other problems with the math:
That is completely missing the point of what I'm trying to get here. I'm generating field equations from a Lagrangian, and using the method I've described several times now, in hopes to generate
general relations between curvature terms. I'm not using the Lagrangian to suggest new physics.
And in that post, as in even your latest post, you again continue to complain about the specific math in post 7 which is frustrating, considering I already pointed out
myself that there were errors and therefore we should focus on whether the
method is viable. Heck I even posted a paper containing the
correct field equations that I would obtain if I went back and fixed the errors.
Altabeh said:
As the title of this thread says all we are going to talk about is mathematical so if I got the time to spend on checking the math, I'd be glad to announce the results soon! Remember that all you're doing here is strongly backed up by mathematics and if this part isn't seamless, I can't even predict what'll happen to the theory in the end!
If you insist on seeing the correct field equations, let me link the paper again:
http://arxiv.org/PS_cache/astro-ph/pdf/0410/0410031v2.pdf
equation 15 are the field equations
Going through all the math to get the field equations is unimportant
if the method I'm proposing to use these to get general divergence relations is wrong. I have done no math to prove the method I suggest is valid, only given heuristic arguments. I don't know how to prove one way or the other (besides getting the equations and checking by hand that they have the property I expected). If you know how to do either of these mathematically:
1) How to calculate the covariant gradient of a non-tensor object (like a Christoffel symbol), in which case I could calculate any gradient of a curvature scalar built from the Reimann curvature directly.
or
2) How to prove that the method I'm proposing to generate divergence relations, which hold in general (and not just in some specific theory), will work.
Then that would be of great help, and I'd love to hear those math details.
Complaining about mistakes in post #7, that I've already pointed out myself and furthermore linked to the correct equations later, is not helpful.
Altabeh said:
[...in response to step 3...]
Your theory has to be divergence-less and this can be obtained by taking the covariant derivative of the left-hand side of the field equations without even looking at the other side. This step compels the theory 1) go astray from the main road, i.e. the generality of equations for any material distribution given, and 2) nullifies the effect of "divergence" because it's already zero! It is mandatory for this step to be modified to give the correct equations! Also
[...in response to step 4...]
will only be valid then in a vacuum spacetime.
I'm sorry. I've reread this multiple times. I cannot figure out what you are trying to say here.
Are you saying the field equations obtained this way "have to be divergence-less" due to the mathematical way in which they were derived? If so, can you please show me how you know that? That is what I've been asking about this method.
But then you go on to say that looking at the vacuum case "compels the theory 1) go astray from the main road". And that "It is mandatory for this step to be modified to give the correct equations!" Modified to what? Astray from what? I think you are still misunderstanding what this thread is about.
I am trying to obtain relations between divergences of curvature terms. And I hit about this some-what bizarre method to generate them, and I'm pursuing it
because I don't know how to find them another way (and no one has suggested an alternate way).
The final comment you make there is that what I obtain will NOT be relations
which hold in general. So you seem to strongly
disagree with my method, but this seems to contradict your first statement that the equations must be divergence-less.
Did you only mean they "have to be divergence-less" in the sense that for the field equations to make physical sense the solutions to the equations must be divergence-less?
