Divergence Theorem/Flux Integral Help
The problem involves computing the flux of the vector field F = xi + yj + zk through the curved surface of a cylinder defined by x² + y² = 1, bounded by two planes. The context is centered around the application of the Divergence Theorem and flux integrals in vector calculus.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss setting up a triple integral after calculating the divergence of F. There are suggestions to switch to cylindrical coordinates for integration. Some participants express confusion over why their calculated flux values differ from expected results.
Multiple interpretations of the problem are being explored, particularly regarding the calculation of flux through the curved surface versus the entire volume. Guidance has been offered on considering the contributions from the top and bottom surfaces of the cylinder, and some participants are questioning their understanding of the integration process.
Participants note that the problem requires careful consideration of the surfaces involved, particularly how the planes intersect the cylinder and the implications for calculating flux. There is also mention of potential misinterpretations regarding the nature of the surfaces being integrated over.
emzee1
Compute the flux of F=xi+yj+zk through the curved surface of the cylinder x2+y2=1 bounded below by the plane x+y+z=1, above by the plane x+y+z=7, and oriented away from the z-axis.
div(F) = (dF/dx) + (dF/dy) + (dF/dz)
Basically all I did was set up a triple integral after finding div(F=3.
∫∫∫ (3) dz dy dx
Limits of the right most integral = 1-x-y to 7-x-y
Limits of the middle integral: -sqrt(1-x^2) to sqrt(1-x^2)
Limits of the left integral: -1 to 1
I got 18(pi) as my answer but it's wrong. Any help on this?
You would have to show your work. It looks like your set up is OK. But I would advise switching to integrate in cylindrical coordinates instead. I can practically do it in my head, the height is 6 everywhere, over the area is π. So I think the answer is 18π also. Why do you think this is not the right answer?
I also got 18pi, but since it's an online homework question, it says that I'm wrong. I have no idea why. Got 18pi in both Cartesian coordinates and cylindrical.
When you integrate the divergence, you're calculating the flux through all surfaces of the volume. The problem asked you to find the flux only through the curved surface of the cylinder.
Does that mean I have to substract the flux from the bottom of the cylinder as well as the top? How would I go about doing that since they are planes intersecting the cylinder, and in essence I think are ellipses.
I failed to read the question carefully, thank you vela!
That surface integral does not look nice just looking at it, may want to try
[tex]\iint_A+\iint_B=\iint_{A\cup B}=\iiint_V[/tex]
Where the triple integral is 18π as we found.
[itex]A[/itex] is the round part of the surface, which may be at least annoying to compute,
[itex]B[/itex] is the two planar lids to the volume, which looks easier to calculate.
Their shadows are not ellipses.
Oh okay. So basically parameterize 2 circles in terms of r and theta, where r goes from 0 to 1 and theta goes from 0 to 2*pi ? And do the integration from there?
Alright, thanks guys, got the question correct.
Just did a double integral, with the integrand 3r dr d(theta) with the limits for dr going from 0 to 1 and for theta, 0 to 2*pi. Multiplied that by 2 since we have a top and bottom to take care of, and subtracted that (which was 6*pi) from 18*pi.
[STRIKE]Now that I think about it, I'm a little worried, what is [itex]\textbf{F}\cdot d\textbf{A}[/itex] along the lids?[/STRIKE]
was repeated below
Now that I think about it, I'm a little worried, what is [itex]\textbf{F}\cdot d\textbf{A}[/itex] along the lids? But if you notice some niceties, the x and y contributions will cancel, and you just need the difference in z again, which is 6, so 6π. I'm not sure you used the right steps to get the right answer, it appears you integrate the divergence over the lids, that doesn't seem right.
Really? I have no idea how that happened, but that's one heck of a coincidence...
did I have to do the integrated of F*dA along the lids to get the answer?
Yes. So typically you should have a formula for [itex]d\textbf{A}[/itex] when you parametrize the surface, which shouldn't be hard, or you can look at the surface as a "graph" of z(x,y) (special case of the more general paramtrization), and they have a neat formula for that.
So even in that case I'd be just looking at the shadows of the elliptical lids (aka circles)?
yes, if you're parametrization or graph was over x-y plane. Rememeber that is due to an absolute constraint by the circular cylinder.
