Do current sources stack with current?
  • Thread starter Thread starter ainster31
    Current Sources
5 replies · 2K views · last reply
ainster31
Consider the following circuit:
Half-wave rectifier schematic: sine source V1 (1 kHz) through R_SRC 10 Ω and diode D1 1N5817 to a node with C1 10 µF to ground, feeding R_LOAD 100 Ω; labelled nodes in and out, current Io shown.
Now imagine that I add a 3A current source:
Circuit schematic: sine voltage source V1 (1 kHz) feeds series resistor R_SRC 10 Ω, diode D1 1N5817, then parallel capacitor C1 10 µF and load R_LOAD 100 Ω to ground, with a 3 A current source in the lower branch and current I1 labeled.
Is the following equation correct? $$I_1=I_0+3$$
No, I1 is by definition 3 amps. You cannot put ideal current sources in series just as you cannot put ideal voltage sources in parallel. Doing either one causes a contradiction.
What would happen in real life if I did add the current source? Will the circuit explode? Or will it just become non-ideal? Will it convert from current source to voltage source? How do voltage sources and current sources even work?
If we use the analogy of comparing electric potentials to gravitational potentials, are voltage sources like ladders or slides?
Real current sources have a range of voltage that can be applied across them and still work. This voltage range is often called the "compliance" range. If you try to operate a real current source outside of this range, it no longer is a constant current source, and usually will put out less than the intended current.
If you stack 2 current sources that have different current ratings, generally the higher current one will go out of compliance, and will output only the current that the lower current source is rated at. Thus, both current sources in series are passing the same (lower) current.
You can see this for youself -- look up common circuits for a current sink and a current source. Then stack the two schematics and figure out what will happen... (fun exercise) :smile:
Sorry, I have no idea what that means.
In real life, current sources are NEVER ideal so the question you seem to be asking (what would happen if I put ideal current source in series) doesn't make sense. Berkeman has explained what will likely happen if you put real current sources in series.
I see the circuit posted as a current source in series with a voltage source. There is no reason that cannot be done.
