Do dimensions of a piezoelectric material affect voltage?
The discussion centers on the impact of the dimensions of piezoelectric materials on voltage generation when subjected to pressure. It is established that the thickness of a piezoelectric block, when sandwiched between parallel plate conductors, directly influences the generated voltage, with thicker materials exhibiting different geometric changes under applied force. Stacking two piezoelectric crystals increases total deformation under pressure, similar to the behavior of springs arranged end-to-end. The conversation emphasizes that the voltage output is proportional to the distance between the plates of the configuration.
  • Understanding of piezoelectric materials and their properties
  • Knowledge of parallel plate capacitor configurations
  • Familiarity with mechanical deformation principles
  • Basic concepts of voltage generation in response to pressure
  • Research the principles of piezoelectricity and its applications in sensors
  • Explore the effects of material thickness on voltage output in piezoelectric devices
  • Investigate the mechanical properties of materials under pressure
  • Learn about the design and optimization of parallel plate capacitors with piezoelectric dielectrics
Engineers, researchers, and students in materials science, electrical engineering, and mechanical engineering who are interested in the applications of piezoelectric materials and their voltage generation characteristics.
iScience
Consider a block of a piezoelectric material sandwiched between two parallel plate conductors, sort of like a parallel plate capacitor with a piezoelectric material as its "dielectric."
If applying the same pressure to two of these configurations, does the thickness of the piezoelectric block affect the generated voltage?
What would happen if you stacked two such devices on top of each other, and then squeezed both of them with the same force? What happens to two springs when arranged end-to-end?
I think the major thing you will find is that a thicker crystal will have different changes in geometry when you apply a given amount of force. So if the system you are trying to measure behaves differently under such different small changes in geometry, you may get different results.
Example: Suppose you are trying to measure the change in shape of a surface by putting p-crystals at intervals. If the surface is changing due to forces that are very large compared to the force required to change the size of the crystal, then the crystal being there may not change the shape of the surface very much. You might see this in the case of machining a surface then putting it on a gauge to check the change in thickness. So the force required to squish the crystal might be tiny compared to the force required to deflect the surface.
I don't actually know whether any process actually uses p-crystals in such a fashion.
But if you were looking for changes due forces that are small compared to the force to compress the crystal, then it might make a difference. Two crystals stacked will deform more (in total) under a given force, just as two springs end-to-end will deform more (in total) under a given force. So if you were looking for the change in geometry of a tank being pressurized, and the crystal required a force similar to the pressure you were using in the tank, then two crystals stacked might well produce a very different signal to one crystal.
If by thickness you mean the distance between the plates then yes.
The voltage is proportional to this distance.
  • · Replies 33 ·
17K
