Do relativistic effects make the age of the universe moot?
The discussion revolves around the implications of relativistic effects on the measurement of the age of the universe, particularly in the context of time dilation due to mass and velocity. Participants explore whether these effects render the concept of a singular age for the universe moot, considering different reference frames and the nature of observers.
  • Some participants question how the age of the universe can be determined given that time passes at different rates due to relativistic effects.
  • Others clarify that the age is typically defined from the perspective of a co-moving observer, who experiences the cosmic microwave background as isotropic.
  • A participant notes that while different observers may measure different times, this does not invalidate the concept of the universe's age; it requires specification of the observer's frame.
  • Some argue that the differences in perceived time due to relativistic effects are relatively small compared to the uncertainties in the age measurement itself.
  • One participant suggests that the maximum observed age is defined by an observer who sees the cosmic microwave background uniformly, which is the age commonly referenced.
  • There is a discussion about the relevance of time dilation effects near black holes and how they relate to the age of the universe, with some asserting that such effects are not pertinent to the age measurement.
  • Another participant introduces the idea that cosmic inflation may have relativistic effects, but concludes that these do not alter the understanding of the age of the universe for co-moving observers.
Participants express differing views on the implications of relativistic effects on the age of the universe. While some assert that these effects complicate the measurement, others maintain that the age can still be defined meaningfully. No consensus is reached regarding the extent to which relativistic effects impact the concept of a singular age for the universe.
Participants highlight the importance of specifying the observer's frame when discussing the age of the universe, as well as the limitations of different reference frames in measuring time. There is acknowledgment of the uncertainties involved in age measurements, which are significantly larger than the differences introduced by relativistic effects.
Andy DS
How can we know the age of the universe, with time dilation due to the mass and velocity of matter which condensed after the big bang. If time passes at different speeds depending where it is perceived, does this not make the age of the universe somewhat moot.
Space news on Phys.org
The age usually quoted is the proper time since the singularity for a co-moving observer, one who sees the CMB as isotropic. This turns out to be the maximum time that can have been experienced by observers at a given event.
The age of the universe is generally given in comoving coordinates, involving cosmological time:
https://en.wikipedia.org/wiki/Cosmic_time
If you want to quote the age of the universe in the reference frame of, say, a particle being accelerated at CERN, then that gives a different, but not very useful, time.
Because different observers perceive time passing at different rates does not make the question of how much time has passed moot. It just means that you have to specify some details about your observer. Typically one quotes this for a "co-moving observer" who is moving along with the expansion of the universe. Also, most of the matter in the universe is moving at relatively slow speeds and in regions of relatively low gravitational potentials so that these corrections are small. Your question is like saying, "Because clocks read different times in different cities on Earth, there is no way to know what time it is."
I think that is very different, as those are just different offsets. We all agree about the passage of time.
We can't find The One True Age of The Universe, because there is no One True Age of The Universe.
So what?
We can still define useful quantities, like @Ibix did with the age of a comoving observer. Or we could point out that the difference between all the times one is likely to use is small. The difference between the Earth's frame and a comoving frame is about 30000 years over the lifetime of the universe. The uncertainty on the age of the universe is about 40 million years - a thousand times larger.
"Your question is like saying, "Because clocks read different times in different cities on Earth, there is no way to know what time it is.""
No phyzguy, my queasion was more like because a clock on Earth and one near a black hole run at different rates, can this effect the answer.
Ok, but what's the problem? I don't see why this makes the question/answer moot.
But if we want to know the age of the universe, the observed passage of time near a black hole is irrelevant.
I thought I'd add my two cents to the pile.
Time dilation shortens the apparent age of the universe. That is, if you are moving quickly compared to the galaxies in our universe, observers in galaxies will see your clock ticking slowly. Which means that you will observe a shorter age.
And there is no bound to how short the observed age could possibly be. If you could travel at a high enough speed, you could in principle see less than a second pass since the big bang (this isn't a practical possibility because matter would slow you down through friction, but that's a different question).
But there is a limit to how long the observed time could be. And the maximum observed age is the age as observed by a somebody who sees the cosmic microwave background having the same average temperature in every direction. This is known as a "co-moving observer", as others have mentioned: they travel along with the expansion.
We aren't exactly co-moving observers, but we're close. From memory, our velocity with respect to the background is something like 600km/s. Which leads to a current time dilation factor of about 0.0002%. The actual time dilation from the big bang for the matter that makes us up wouldn't be exactly this (because it's moved around a bunch), but it'd be close. That error is much smaller than our current measurement error (around 0.2% or so, a hundred times greater), so it's generally ignored.
And that maximum age is the age that is being referred to when the term "the age of the universe" is used.
More precisely, when we talk about "the age of the universe" we've just chosen not to talk about the passage of time near a black hole, although that would be different.
For @Andy DS, an analogy is speeds. The speed limit on most roads around here is 30mph. But the Earth is doing about 20km/s around the Sun - how can we stay below 30mph when we're doing 20km/s just sitting here? The point, of course, is that by "30mph" we actually mean "30mph compared to the surface of the Earth where I am". Nobody bothers saying the bit in italics because people just understand it (possibly due to never questioning whether it could mean anything else, one suspects), but the qualification is important because it is also true that I'm currently doing 20km/s around the Sun, and many other speeds with respect to many other reference points.
That doesn't mean that it's impossible to define my speed. It just means that "my speed" needs a bit of qualification - my speed compared to what. Similarly with the age of the universe - strictly we should say "the age of the universe as measured by an observer who sees (and has always seen) the CMB as isotropic". But, like the ground frame in the speed limits, the isotropic-CMB observer is an obvious (obvious to cosmologists, anyway) type of observer to use to define age. Most people are either aware of which type of observer is being used in unqualified statements about the age, or aren't aware of or interested in the subtleties. Welcome to the first group. 😁
I see where all the replies are pointing and many thanks.
I was thinking that during cosmic inflation there may have had some relativistic effects but if we are saying this doesn't have an effect on what we know about the age of the universe because we are all riding along on the same wave I think I understand now.
As long as you only mean the bit I've bolded figuratively, then yes. Inflation doesn't change co-moving observers into non-comoving ones or vice versa, would be a more precise way of putting it.
Yup, that's correct!
  • · Replies 30 ·
  • · Replies 23 ·
