Do you have an example of a truly random phenomenon?
The discussion revolves around the concept of "truly random" phenomena, exploring examples and definitions of randomness outside of quantum physics. Participants debate the nature of randomness, its implications in physics, and whether certain processes can be considered truly random or merely unpredictable.
  • Some participants argue that if all data about a phenomenon were known, it could theoretically be predicted, questioning the existence of truly random phenomena outside quantum mechanics.
  • Others suggest that radioactive decay might be an example of randomness, although it is debated whether this falls under quantum phenomena.
  • A participant raises the idea of deterministic chaos, questioning if unpredictability in chaotic systems could be considered true randomness.
  • There is a discussion about the origins of probability and randomness in gambling, with some asserting that true randomness requires outcomes that are unpredictable even to the most knowledgeable observers.
  • One participant claims that randomness is a mathematical concept and suggests that the discussion may not lead to useful conclusions.
  • Another proposes a method involving Johnson white noise sources to generate unpredictable bits, emphasizing the challenges of achieving true randomness in computing.
  • Concerns are raised about the practical implications of randomness in physics and whether certain processes can be deemed random or merely random enough for practical purposes.
Participants express multiple competing views on the definition and existence of truly random phenomena, with no consensus reached on what constitutes true randomness outside quantum mechanics.
Participants acknowledge the complexity of defining randomness, with discussions highlighting the dependence on interpretations of determinism, chaos, and the role of quantum mechanics. The limitations of practical examples and the implications of manipulation in experiments are also noted.
  • #31
The_Baron said:
I tried to think of a truly random phenomena thatis not related to quantum physics, and i can't. Let's take heads or tails as an example, if you had all of the data about the throwing of the coin you could tell on which side it will land.
So does anyone know a random phenomena?
Weather.
  • #32
We don't know for certain that anything is truly random -- it may be that everything is causally determined precisely -- many things appear to be very reliably random from our perspective . . .
Weather.
Yeah -- random.org uses atmospheric noise -- you can get some random bytes here: https://www.random.org/bytes/
  • #33
I used to think that an electron's motion around a nucleus is a truly random event, since (and according to Copenhagen interpretation of the wave function) we can talk only with probabilities about whether an electron is at a specific location. But it turns out that these probabilities obey a deterministic law, i.e. Schrödinger equation.
I tend to think that the universe is not truly random (of course it isn't since at least macroscopically there appears to be some sort of deterministic laws and order) but it is neither fully deterministic either. It is ,SOMEHOW, something in between.
  • #34
PeroK said:
It only takes a finite amount of information to identify ##\sqrt 2##, for example. Mathematically that is completely defined by what I have written.. The infinite decimal expansion is not needed to identify the number.
What I said was "Points are fictions, because it would take infinite information to identify any point".
If the point that you reckon is identified by ##\sqrt 2## because it has the notional coordinate value ##\sqrt 2## is defined, then you imply that there is no other point that can be confused with it. (Otherwise how could you support the claim that it is defined?)
OK, but mathematically there is no coordinate in the continuum that is not associated with exactly one point, no more, no less. (Unless you have a real surprise up someone's sleeve.)
Right?
OK again, now go back to your continuum line, and remove precisely the ##\sqrt 2## point.
Which two points had been on either side of it? Pray tell how would you distinguish them from ##\sqrt 2## without infinite information?
And then, for an encore, do the same for plain vanilla ##2## (if my notation is correct).
After which, demonstrate how you would display any item of infinite information in any finite universe.
Our numeric notation really comes down to a fiction; much as a map is not the territory, but just a caricature close enough for certain purposes.
  • #35
Dale said:
Sorry, but your personal opinion on the matter is unconvincing.
Sorry, but your personal opinion on the matter is unconvincing. Do you have an actual peer reviewed reference to support that assertion?
Show me a peer-reviewed reference to establish that
6798214808651328230664709384*460955058223172535940812848=
3133671502935506745060193180452403351940034608653365632
  • Skeptical
  • #36
@Jon Richfield You appear to me be attempting to assert limitation against the power of language to define the definable. Whatever the exact value of it is, the square root of two is definitely exactly that number which multplied by itself equals two (as @PeroK indicated), and to know what two is, you have have only to look at your hands, and count as high as almost any mammal can (almost any mammal can distinguish between one and more than one) until you get past one, and then stop. What will you do when the irrational number ##\pi## is perfectly precisely defined as that number which is equal to the ratio of the circumference of a circle to its diameter?
  • #37
How do we know a physical system with a continuous state (e.g. the distance between two particles in the system) is in a state of exactly 2, and not one of the infinitely many other values that lies within an arbitrary small ball around 2?
  • #38
The examples you cite are OK in everyday utility, much as you can go to the grocer to buy "a kilo of butter" or "a litre of milk", but, like the map I mentioned, they are fictions. Would you show me an exact hand? And then undertake to show me that hand again? (Or two hands for that matter?) I hardly think so.
And how about showing me an exact circle? Fat chance! There is no such thing: no matter the precision of the equipment you draw it with, or indicate its position in space, it is a formal fiction, with, at one's most charitable, a fuzzy circumference with a poorly defined diameter, that is at all times greater than pi times an idealised diameter.
But two? Which two did you have in mind as defining the coordinate of a point on a notional line, which is what I specifically referred to? I was not speaking of an ordinal 2, which in its artificially conceived integer role of counting only represents a few or perhaps a few million (fat chance!) bits of information, but the value of a coordinate on a line. Not a segment of the line, please note, much less a fuzzy segment, but a point. Without that you simply have not defined the number, just a region with fuzzy boundaries limited by the information at your disposal. If you can discriminate the identity of two even to a precision of say, one googol bits, I would be impressed, though incredulous, but it would do nothing to dispel the vagueness of your identification of a particular point.
In the example(s) you gave, "the power of language to define the definable" is extremely limited, partly by the circularity of its definition; the notional ability of language in this case is not mathematical, but fictional, the pretense at defining the indefinable.
Try again your definition and demonstration of the existence of the number two as distinct from other numbers, not on toy examples of limited sets, such as hands or eggs of hens or of salmon, but points on the continuum.
Not in this universe, words or no words.
  • #39
There's no need for a peer-reviewed reference to establish correctness or incorrectness of that equation.
  • #40
Same for the amount of info required to distinguish a point.
Elementary.
  • #41
Elementary.
Disagree. You can fuss about the definition of a point. The answer to a multiplication of two finite integers is inarguable.
  • #42
Dale said:
I have been thinking about this response and have decided that is a good one.
My formulation is based on the following sentence in Sir Arthur Stanley Eddington’s book „THE NATURE OF THE PHYSICAL WORLD“ (which I highly recommend): „This follows at once if our fundamental contention is admitted that the introduction of randomness is the only thing which cannot be undone.
  • #43
You can no more (or less fuss about the definition of a point than about anything else; if your definition is not precise enough to distinguish it from every other point you don't have a point, just hand-waving.
Sort of like a high-school geometry problem that you try to solve by saying that the sketch looks sort of equilateral or right angled or something. A point has zero length. it has zero freedom in its coordinates. Anything else and it is not a point. Zero is zero. It is not less than zero. It is no more than zero, not by a kilometre, a light year, a Planck distance.
Zero.
Of course, you might insist that I am being too demanding, but then you are conceding the point that there is no point. Especially where there is fuss. Otherwise known as hand-waving.
  • #45
  • #46
@Jon Richfield this is an inappropriate response to a request for a reference. In this forum we require that everyone put aside their personal opinions and post only content that is consistent with the professional scientific literature. One way we ensure that is the case is by asking for and providing references when claims are made.
You have made some claims that I suspect are personal speculation, but I don’t know all of the scientific literature. So asking for references gives you an opportunity either to retract your claim or to educate me. This is not something we take lightly here.
To be clear, your claim that I question is
Jon Richfield said:
But information is finite.
Which is specifically in reference to
Jon Richfield said:
in terms of objective reality, to the extent that information existing in the universe does not exist, as opposed to the information that is available to you.
So the claim is not based on human information, but on information existing in the universe. I know of nothing classically which places a fundamental limit on information.
  • #47
On this thread I would say your hands are waving more frantically that anyone else's!
  • #48
It was entirely appropriate for the offensive context and tone of your demand, which I simply echoed. This subject matter is no more the stuff of peer review than 2K=mv^2; it is standard material available in various forms and contexts either in textbooks or online in the likes of Wikipedia articles on cosmology, astrophysics, information and thermodynamics. To suggest that I was no more than cramming my own conceptions and thumbsucks down other participants' throats (as expessed in "your personal opinion on the matter is unconvincing. Do you have an actual peer reviewed reference to support that assertion?") was downright insulting, and my response was at least as justifiable.
I don't know what you mean by classical in this context, given that thermodynamics dates back only some two centuries, and in any case, what is largely regarded as non-classical started more or less with relativity, QM, and arguably information theory, but none of them affected the relevant basic theories apart from the dismissal of caloric. One could have made a very similar case for the realities of the limits to information in terms of F=ma, if only they had been thinking in those terms in Newton's day. The main thing missing at that time was that there was no concept of observation boundaries or other limits to our meaningful access to verifiable observation. IOW, the implication was that the universe was effectively infinite, so that there would have been no logical limit to the info it could accommodate. Nowadays we are far cosier in our little 10-odd gigaparsec nook, so we have to do with what there is room for and material for.
If you are denying such received wisdom, stop and check out the idea of what constitutes information. Never mind the hard graft of digging for texts, ask yourself why we speak of BInary digiTs. You cannot store, transmit or process information in any form but matter, energy and their physical relationships. Don't blame me, lay it on the likes of Boltzmann, von Neumann, Shannon, Penrose... Hmmm even Einstein, Podolsky, Rosen and Bohr. Check out the current interest in the ratio between the information content of the surface area of a black hole and its surface area.
And you want me to go back and check out their peer reviews for you?
Work it out for yourself: ask yourself how many fermions and bosons there are in the observable universe: aleph-nul? Aleph-n? Ask yourself how many bits of info you can store and retrieve from each particle or quantum.
Then ask yourself how much info there is room for in our universe.
  • Skeptical
  • Sad
  • #49
Welll... suppose you give an example? What did I say that contradicts, or does not follow, from commonsense everyday transactions on the one hand, or formal mathematics or logic on the other?
I didn't invent, say, post-Galileo physics or maths, or astronomy, and I invoke nothing novel, nor predict nothing that is not generally refuted either. Are you going to pull a Dale on me and ask for peer reviews on Boltzmann for example? or of von Neumann's application of entropy to information?
Don't spare my feelings: point out my handwaving. Show how you can have information independent of matter/energy. And show how you can have an infinite-digit expansion of pi without an infinite amount of matter/energy, or an infinite brain to accommodate it, not to mention gravitational collapse. And work out how long it would take you to perform any operation (such as comparison) on a digit say one Gparsec down the line from where you are assimilating nearer digits.
  • Skeptical
  • Sad
  • #50
How about this hypothetical. Say that you can count the air molecules in a volume of air. And you know the average. Say 1000. Wouldn't the over-under be a random event? (this supposes you can snapshot and add in all the fractional pieces at the edges).
These macro-level random things may all just be Shrodinger boxes. Deep down, depending on some butterfly-effect required precision that exceeds a QM randomness. I might be substituting air molecules for the balls-in-a-bag, mentioned in a previous comment.
  • #51
This post is hand waving and a confusion of physical and mathematical ideas. You've invoked Galileo, Bolzmann and von Neumann which just leads to a certain incoherence of ideas.
Your assertion that ##\pi## requires an infinite amount of information to define is simply false. This is a common error to confuse a number and its infinite decimal expansion. Your ideas in this regard are based on an elementary misunderstanding of pure mathematics.
  • #52
PS ##\sqrt 2## is defined as the positive solution of the equation ##x^2 = 2##. It's decimal expansion is irrelevant mathematically.
  • #53
  • #54
Jon Richfield said:
As some folks point out, randomness is slippery because there are independent definitions. I refer you to the book by the late I. Prigogine: "The End of Certainty". Following its logic, you are left without practically no fully non-random events.
As I see it, the difference between random events and non-random events is information. An event/outcome is random to the extent that you lack information on the event. And it is random in terms of objective reality, to the extent that information existing in the universe does not exist, as opposed to the information that is available to you. If enough information exists to determine how your coin toss works, then the outcome might be random to you, but the universe would "know", and "determine" the outcome in advance.
But information is finite. Now, consider symmetry-breaking. Someone mentioned crumpling paper: a large part of its unpredictable nature is because it involves a lot of symmetry breaking, much of it only roughly, but some of it beyond any probable information available. Even the universe could not tell you exactly how it would crumple.
Let's choose a different form of symmetry breaking: the needle test. Imagine a horizontal rigid surface in a vacuum in neutral gravitational and electromagnetic fields. You have a device that tosses the needle so that at least sometimes that needle lands balanced on its tip. The game is to bet on which way it eventually will topple. Laplace does not forbid such a possibility, and offers no prediction.
The needle and surface offer no information to the universe about how that symmetry will break. To the extent that information on any bias exists, it will affect the direction and reduce the randomness accordingly, and affect the precision of the outcome..
If you happen not to like the needle, try the ball test: start with a rigid surface and vacuum as already described. Take a vertical, symmetrical stack of rigid, notionally perfect spheres of excellent coefficient of restitution, and drop them. As long as there is no information on any asymmetrical bias (not just your ignorance, and ignoring any quantum asymmetry, those balls, in obedience to F=ma, will bounce vertically for a long time till they stop and remain balanced. Right?
Wrong.
For that to happen there would have to be infinite information determining the symmetry of the system. It follows from the nature of the geometry of the balls. But we live in an observable universe that lacks capacity for infinite information.
It follows that, QM or no QM, there could not be a completely non-random system in our universe. And your personal capacity for information is a good deal smaller than that of the universe.
1. There is QM, so any statement that disregards it becomes somewhat meaningless.
2. The needle would not topple. Classical physics would hold that it takes a force for it to move one way or the other. If you know the forces, you know the direction of topple. Absent forces, it doesn't move.
3. Yes. the perfect sphere balls in perfect alignment would stack vertically. That isn't wrong. You say perfect spheres and then say "can't be done". Too hard to get that perfection.
I'm puzzled by your assertion that a requirement for infinite information is the same to you as random. We all agree that ordinary randomness exists. Things can be beyond our ability to predict. And in general, we agree that there are determinate things. Things we can predict.
"there could not be a completely non-random system in our universe."
Double negatives are hard to parse. I read this as:
"there could not be a completely determinate system in our universe."
I can arrange a deck of cards, and know the order of the cards. That is a determinate system. I can cut the deck, without the ability to choose a number of cards, and the card is "random".
I don't need infinite information to know the order of the cards in the deck. I need 52 pieces of information. It is a determinate system. There are non-random systems.
  • #55
Don't 51 positional addresses suffice to establish the 52nd? :wink: (we use that fact in 'bubble' sorts) . . .
  • #56
True.
Although then the 52nd piece of information might be that it is a deck of cards with 4 suits, ace-to-king, and no jokers. But I think you re right ... 51.
  • #57
Yes, that is precisely what a request for references entails. I don’t think any of them made the claim that you are making. It is your claim and the onus is on you to justify it.
  • #58
Lord Jestocost said:
Maybe, one finds answers under the keyword "Bekenstein bound": https://en.wikipedia.org/wiki/Bekenstein_bound
Yes, I did think of that before asking for references, but classically there is nothing that requires the universe to be finite (nor is the universe necessarily finite in GR). So the Bekenstein bound need not be finite either. So I don’t know of any classical requirement that leads to the assertion that information is finite.
  • #59
Filip Larsen said:
But I also guess that Johnson noise is a very clear example of "directly amplified" thermodynamic noise, i.e. quantum noise. I think it is an interesting question if it is possible to make an unpredictable system where the source of uncertainty is not quantum noise, not directly at least.
Back to square 1.
If all things described by QT ceased to operate, our universe and time would cease, along with all the things we call random. Let's accept the fact that QT was always in the background somewhere.
Johnson noise is thermodynamic noise derived from the sum of a great many individual vectors of quantum origin. If I low-pass filter that noise spectrum, I can eliminate all the individual quantum events from the record, leaving only the thermodynamic noise spectrum.
Now, I take two quite independent spectral sources of quantum generated thermodynamic noise, I divide one by the other, so any remaining quantum dimension must be cancelled. I have then eliminated quantum from the deal, what remains is a scalar non-dimensional signal that moves randomly either side of zero in a particular statistical way.
I take two of those quite independent Q free signals and band-pass limit them into two wide but separate parts of the spectrum. They cannot correlate, because their spectra share no common frequency, (the product of their Fourier transforms will always be zero).
I eliminate the amplification gain factor from the process by comparing the band-limited signal voltages with zero, then digitally divide the frequency of the serial bit streams by two with flip-flops, which eliminates any zero offset errors that might bias the result.
I use the positive edges of the slower stream, that occur at random times, as the clock that samples the state of the faster random stream, which yields a sequential stream of random bits.
OK, so the random stream is derived from this QT described universe, but all Q has been eliminated at least twice from the statistics of the signals.
  • #60
It is an interesting model you describe, but it sounds like there are a lot of details in the statistics that has to work out, at least to understand what the process is. I am also not sure what you mean by "eliminating quantum"? I understand it like you use the two junctions to get a normalized (flat) noise spectrum, but that the noise or decorrelation between the two junctions is still directly driven by the thermal (quantum) noise?
Unless I completely misunderstand your description I think my comments still applies about how such a system seem pretty well married to quantum models for its randomness, at least in some practical sense. For example compare this system to, say, a lava lamp, which can have its dynamics modeled using purely classical deterministic laws with its unpredictability originating from the (classical) phenomenon of turbulence. I know that deep down, this randomness of a lava lamp is also tied to quantum phenomenons (like the measurement uncertainty for the initial state of an otherwise classical system), but after establishing an initial state its dynamics seems way more determinstic.
  • · Replies 86 ·
13K
