Does capillary length limit water rise in very thin capillaries?
The discussion centers on the mechanics of water transport in very thin capillaries, particularly in the context of trees. Participants explore the interplay between gravitational forces and adhesive forces in capillary action, questioning the existence and implications of a capillary length limit for water rise in such structures.
  • One participant notes that gravity is proportional to volume (radius squared) while adhesive forces are proportional to surface area (radius), suggesting that for small radii, adhesive forces may dominate over gravity.
  • Another participant questions whether water would rise indefinitely in a very thin perfect tube, raising the issue of capillary length.
  • A later reply clarifies that opposing adhesive forces act only on the meniscus, not along the entire surface of the tube.
  • One participant introduces the concept of transpiration, indicating that it plays a significant role in vertical water transport in trees, creating low pressure that aids in drawing water up the capillaries.
  • Another participant argues that while gravity is balanced by adhesive forces, transpiration contributes to the actual flow of water.
  • It is suggested that a greater length of contact for the same cross-sectional area can support a taller column of water, which is why capillaries are narrow.
  • One participant cites a source indicating that in taller plants, gravity can only be overcome by the decrease in hydrostatic pressure due to water diffusion out of stomata.
Participants express multiple competing views regarding the mechanics of water rise in capillaries, particularly the role of capillary length and the effects of transpiration. The discussion remains unresolved on several points, including the implications of splitting a tube into two menisci.
Participants acknowledge limitations in their understanding of fluid dynamics, which may affect their interpretations of capillary action and transpiration. There are also unresolved questions about the conditions under which capillary length limits water rise.
Medicago
Considering very thin capillaries, such as found in wood to transport water (~100Micron), I understand that the two main factors in play are gravity and the adhesive forces between the water and the surface of the capillary tube.
I understand that gravity is proportional to volume that is (radius)^2 whereas adhesive forces are proportional to inner surface area of tube that is (radius)^1.
So for some small radius adhesive forces are stronger than gravitational pull.
However it seems as if this is independent of length. It seems that since both gravitational pull and adhesive forces, being proportional to volume and surface area, are directly proportional to some ΔL, then the length of the tube is irrelevant and the water will climb up until the tube ends. However, we still define a certain capillary length for capillaries.
Does this capillary length exist for very thin capillaries? Or would water climb indefinitely in a very thin perfect tube?
And if it does exist why would it depend on length anyway?
Thanks.
Well I've found the answer myself.
Apparently the opposing adhesive forces act only on the meniscus!
I thought it was a shear force that acts all along the surface of the tube.
But here's another question:
If I take a tube and split it to two tubes somewhere in the middle, creating two menisci, would that raise the water higher? Considering the diameter doesn't change.
I'm simply looking into the mechanics of water transport in trees and I'm really missing some essential fluid dynamics background so I'm trying to make up for it here..
Thanks.
In trees, a lot of the vertical transport is accomplished by more than pure capillary action. The evaporation (transpiration actually) of moisture out of the leaves also plays an effect. Transpiration causes low pressure at the top of the column which in effect sucks the water up the capillaries. The stomata on the leaves open and close to control transpiration, and therefore vertical flow.
negligible in terms of pressure gradient, chris.
One can assume that gravity is balanced entirely by adhesive forces, whereas transpiration contributes to the actual flow.
Yes, a greater length of contact for the same cross-sectional area will support a taller column of water. That's why the capillaries are narrow.
As Medicago says, capillary action draws water up until the tube is filled, but evaporation from the top makes the capillary action draw up more to keep it filled.
From Wikipedia:
"In taller plants and trees however, the force of gravity can only be overcome by the decrease in hydrostatic (water) pressure in the upper parts of the plants due to the diffusion of water out of stomata into the atmosphere"
14K
12K
  • · Replies 22 ·
56K
