Does electromagnetic radiation from pulsar stars
Chaos' lil bro Order
Does electromagnetic radiation emitted by pulsars carry enough energy as to make the gravity created by these emissions significant enough to gravitationally effect distant objects many light years away? In other words, can a pulsar star or a neutron star, effect distant planets or even distant stars, by perturbing their orbits, but not from the gravity of the pulsar or neutron star itself, but from the gravity created by the actual EM emissions themselves, even light years away. My gut says the gravity is too little, even though if the Earth was in the beam's path it may cook off the atmosphere and us with it. Just out of curiosity, if you could idealize an experiment where a tank, a cubic meter is size, was filled with water and an identical tank was left empty with the challenge to you to fill the empty tank with radiation until the density was sufficiently equal as to cause the same amount of specific gravity as the water tank, how much would it be?
The answer to your first question is "no". Your second question is poorly formed (what units are you looking for?), but the energy would be equal to mc2.
How about MeV.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
