Does Q = enthelpy in Constant Temperature?
5 replies · 2K views
Jameseyboy
In a constant temperature process, where heat is added - Does the enthalpy after the heat is added equal the initial enthalpy plus the Q value?
For an ideal gas, if the temperature is constant, the change in enthalpy is zero.
For my particular question I have steam with a given pressure and dryness fraction. Really not sure what to do here
Enthalpy is a measure of the total energy of a system (relative to some selected "zero point", we have no theory which allows us to determine the absolute energy of any system). In Classical Physics Energy is conserved. It is neither lost nor gained in any isolated system. In Relativity, if you include Mass, Momentum and stress in your definition of Energy, which is the way it works, then Energy is conserved (locally). Meaning the Laws of Thermodynamics are locally obeyed. So, you need to engrave in your soul that unlike vampires, and Magneto, energy can be neither created nor destroyed. Heat is the flow of energy. If energy is flowing into a system, you shouldn't need to ask if enthalpy is increasing by *EXACTLY* the same amount. Of course it is.
Dryness fraction is an engineering term, and until 30 seconds ago, I'd never heard of it.
Try: http://www.engineeringtoolbox.com/wet-steam-quality-d_426.html
or
https://en.wikipedia.org/wiki/Enthalpy–entropy_chart
it seems to be a simple problem of adding components of enthalpy together (computed separately).
No problem. If you have saturated vapor and saturated liquid in equilibrium at a given quality, temperature, and pressure, and you add or remove heat so that the quality changes, then Q = ΔH (provided you don't add or remove enough heat to take you out of the two phase region). Also, ΔS=Q/T.
Chet
Ok makes sense so far just wasn't sure.
It also asks for work later in the question.
(these are only for a few marks as well which is why it's frustrating. The harder questions I have a good idea how they go)
I appreciate the help buddy
