Does quantum entanglement in fact equal a wormhole?
Guthrie Prentice
So I came across this paper claiming that quantum entanglement was an as yet not understood Einstein Rosen-Bridge: http://arxiv.org/pdf/1306.0533v2.pdf
I have two questions pertaining to this:
1. Does the math on this paper actually check out and is this possible?
2. Since this paper: https://hal.archives-ouvertes.fr/hal-00981257/document seems to show experimentally that the Casimir effect can warp space time in a way that Kip Thorne predicted for wormholes, http://authors.library.caltech.edu/9262/1/MORprl88.pdf, could the quantum entanglement paper be tested by holding two entangled photons between plates to generate the Casimir effect, flood one of the photons with other photons and see if photons mysteriously appeared by the other entangled photon to test for wormhole activity?
I'm curious if such theoretical ideas are testable with our modern technology as I'm getting annoyed by hearing continously of the ongoing problems of unfalsifiability in theoretical physics.
Thanks.
I would say yes just because of the two authors. But "possible", since we're far from experimental checks as you say, isn't a big deal.
Thanks.
Welcome to PhysicsForums, Guthrie!
There are a number of different issues being raised here. The authors are not saying that all entanglement is due to relativistic features such as an Einstein Rosen bridge. They are asserting that exotic relativistic structures could exhibit entanglement. They also speculate that quantum gravity exists. No one knows if that is true or not.
This is some fairly advanced material on the edge of theory. So you should expect that the experimental conditions to test these may not be feasible anytime soon.
As to problems of falsifiability in theoretical physics: there are plenty of things being checked out every day. Each scientist has their own path to follow. But the frontiers of science grow constantly, and this is a very exciting time in the areas of entanglement and of general relativity (now celebrating its 100th anniversery).
Likes e.bar.goum
Hmm they are suggesting that: "ER=EPR [...] we are going to take the radical position that in a theory of quantum gravity they are inseparably linked, even for systems consisting of no more than a pair of entangled particles."
Yes I saw that. That is part of their speculation about quantum gravity. This is a complicated premise of theirs. I would not call it established science in any respect. The authors are well-respected. You really must take this paper in a special light, this is not at all intended for the usual discussion. If you don't follow the subject of advanced general relativity and quantum gravity closely, it doesn't make a lot of sense.
I would say that from the perspective of established science: there is absolutely no connection between any known type of entanglement and a pair of black holes.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
