Does Resistance Truly Reach Zero at Absolute Zero?
The discussion revolves around the behavior of electrical resistance in conductors as temperature approaches absolute zero, specifically questioning whether resistance reaches zero or remains at a small value. It explores concepts related to superconductivity, the implications of infinite current, and the characteristics of different materials at low temperatures.
  • Some participants speculate that resistance in metallic conductors decreases with temperature and question if it reaches zero at absolute zero or remains a small value.
  • One participant argues that if resistance were zero, short-circuiting an ideal voltage source would lead to infinite current, which they believe is physically impossible.
  • Another participant mentions that near absolute zero, normal conductors still exhibit some resistance, while superconductors drop to zero resistance below a critical temperature.
  • There is a discussion about the role of inductance in a wire with zero resistance, suggesting that it would limit the rate of current increase.
  • Some participants clarify that superconductors, such as copper and gold, do not exhibit superconductivity at low temperatures, while others mention silver as a potential superconductor.
  • One participant notes that superconductors have a maximum current density and can quench if too much current is enforced, leading to resistance and heating.
  • There is a debate about the drift speed of an "infinite current," with one participant stating that any statement about drift speed based on an infinite current premise is valid due to the nature of false premises.
Participants express multiple competing views regarding the behavior of resistance at absolute zero and the implications of superconductivity. The discussion remains unresolved, with no consensus on whether resistance reaches zero or what the implications of infinite current might be.
Participants reference various physical principles, such as inductance and capacitance, in relation to current behavior in superconductors and normal conductors, but the discussion does not resolve the underlying assumptions or definitions related to these concepts.
freefaller
I was wondering, since resistance decreases along with temperature for most metallic conductors (usually power function), in theory, if this conductor were to be at zero kelvin, would the resistance of this material also be precisely zero, or would it just be some extremely small value?
If it was zero ohms, then short circuiting an ideal voltage source with a wire in these conditions would create an infinite current, which i believe is physically impossible, and so we have yet another reason why absolute zero isn't achievable. However it doesn't rule it out theoretically.
Anyway, does anyone have any ideas on the matter?
Nothing gets to absolute zero, but when you get really close, it's my understanding that the resistance goes to zero because the mechanism that causes resistance goes away.
As for an idea power supply, there is no such thing so your statement is not meaningful.
I know those things are not possible, I was just speculating. There's no need to get heated.
Anyways thanks for replying. I took a little time to look more extensively and i found the following:
Even near absolute zero, a real sample of a normal conductor shows some resistance. In a superconductor, the resistance drops abruptly to zero when the material is cooled below its critical temperature.
But maybe you're right. What particular mechanism did you have in mind?
It is wrong to think that you will have an infinite current.
The wire could well have zero resistance (this is what superconductors are) but the wire will also have an inductance which (as far as I know) is not temperature dependent. The inductance determines the rate at which current will rise so the best you can say is that a wire with resistance = 0 but inductance = 10H (for the sake of argument) will be observed to have a current increasing at 1A/s when connected to
10V (e = Ldi/dt)
Yes, that's correct. I SHOULD have said superconductors, not just any material.
To my considerably surprize, when I looked at superconductors briefly last year, I found that two of the best conductors I am aware of, copper and gold, are NOT superconductors near zero degrees.
I asked an ECE phd student I recently met about this, and he told me that it would only impede the current from reaching an infinite amount if it were alternating. Probably though, for direct current, capacitance (I guess normal wires have tiny capacitance just as inductance?) would kick in having the same effect.
Ok, thank you for the replies, you've all been very helpful.
Anyway, you can't SUPPLY infinite current, so whether or not it has that capacity is irrelevant from a practical point of view.
What would be the drift speed of this so called infinite current?
Anything you want it to be.
The statement
"If the current is infinite, the drift speed is X"
Is an absolutely true statement regardless of what X is because a false premise implies any result you like.
You haven't heard of silver? :P
Superconductors have a maximal current density - try to enforce more current, and they will stop to be superconducting. The resistance heats the superconductor, it can carry even less current, and heats more, and you get a nice quench.
While the current is not infinite, it can stay circulating for (nearly) an infinite time in a superconducting circuit.
  • · Replies 57 ·
15K
  • · Replies 19 ·
