Does the distance affect the landing of a bouncing die?
  • Thread starter Thread starter 111111
    Physics
The discussion centers on whether the distance a die is dropped affects its landing position and side. It highlights that while a perfectly controlled drop could yield consistent results, factors like air motion and surface imperfections introduce variability. Quantum mechanics is mentioned, but it's clarified that its effects are negligible at the scale of a die or BB. The conversation suggests that larger objects like cubic dice are less susceptible to randomness compared to smaller ones. Ultimately, the distance of the drop does influence the outcome due to the amplification of imperfections, but this is not directly related to quantum mechanics.
111111
Lets say you have a die and a galton board (a vertical array of pegs used to demonstrate the normal distribution), you build some kind of apparatus that will allow you to drop the die from the exact location, with the exact degree of tilt, ect, repeatedly. You also have a super slow motion camera to capture its decent.
Question: Will the die follow the exact path each time, and land on the same side? I have heard that quantum mechanics says that the die would only have probabilities of where it would land.
It's more chaos theory, how accurately can you drop it at exactly the same angle in the same point. Then you have to worry about air motion, then the thermal motion of atoms on the surface of the die and the pegs.
Yeah. Quantum effects are not going to manifest themselves very readily in your situation. the more exact you build the dropper, board and what not, the more consistant your die drop will be. If you use something as large as a cubic die, you can ensure that you get the same value. Something smaller like a BB would get you more random results.
So would a BB actually be affected by quantum mechanics? I am just wondering if quantum mechanics theoretically happens on the scale of inches, feet, miles, ect, or if it is only something that occurs at the level of photons, electrons, ect.
I would have though that the distane in which the die is dropped would have an effect, as the further it is dropped the greater any imperfection will be exagerated, this is the same as with the size of the bases of the die. This itself I do not think is in any way related to Quantum mechanics but I think it still apllies.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
