Does time run fast near universe's edge?
  • Thread starter Thread starter ksertatas
    Edge Time
The discussion centers on the misconception of an "edge" or "center" of the universe, emphasizing that mainstream cosmology does not support these concepts. It explains that while the observable universe has a center from our perspective, the universe itself is infinite and lacks a definitive center or edge. Time appears to run slower at the limits of the observable universe due to the stretching of light waves, but this is an optical effect rather than a change in the fundamental nature of time. The conversation also touches on gravitational effects on time, noting that while time does vary slightly in different gravitational fields, the proposed idea of a "time center" lacks scientific basis. Overall, the thread clarifies that current physics does not support significant variations in time based on location within the universe.
ksertatas
Hello all, this is my first post. My question is, do any theories exist about time relativity based on distance from universe's center? Also interested your own opinions on the subject.
Thanks,
kadir
Astronomy news on Phys.org
There is no edge!
Thanks,
kadir
There is no edge and no center to the universe. There is some further discussion here:
www.phinds.com/balloonanalogy
Thanks,
kadir
I think the simple answer to your question is probably "no".
In ordinary professional mainstream cosmology your question is meaningless because the universe has no "edge" and no "center".
The part of it that we are currently able to SEE has a center, of course, and we are the center of that region. That region is the currently observable universe. It is a growing region because as time goes on we see more and more.
But the observable region is not the whole thing.
Out near the limits of the observable region we see the matter as it was a long time ago. But there is no indication that physics out there is any different from what it is here.
We get the NEWS from out there in a slowed-down stretched out version because of the expansion of distances that has occurred over the billions of years the light has been traveling. You can see how that would happen--the signal stream has gotten stretched out so there is an APPARENT slowing of time.
But we can allow for that. We see the light from glowing-hot clouds of gas which were out there, and the light has been cooled by having its wavelengths stretched out 1000-fold so it isn't even visible light anymore---just microwave you pick up with a radio dish antenna. But we allow for that. We know the light was originally 3000 degree hot glow, even though it now looks like only 3 degrees. A thousand times cooler.
You could say that time APPEARS to be 1000-fold slower out there near the limit of what we can see. But that is just appearance. The indications are that physics was just the same then as it is now.
Thanks for replies. I need some time read these materials. I see there is not a volumetric center of universe. My main question is, does speed of time change based on your location. I mean perhaps time runs faster in somewhere so called -time center- and slows down while you go away from that center. If we can assume that there is such a time speed reference difference, can we think universal gravity coefficient may vary and even go negative?
Note: I am not a physics student or someone reads scientific publications.
Thanks,
kadir
There IS no center. You need to drop that idea.
No, as far as I can tell, what you are suggesting has no basis in physics at all, it's just something you have made up.
There IS a difference in time inside a gravity well and outside, but unless you are talking about a black hole, the differences are small.
GPS systems require correction due to the fact that the transmitters are higher out of Earth's gravity well than the receivers are.
Of course i am making these up. Just asking that are there any theories or studies similar to that idea. I am trying to understand why gravitational pull quits when high distances take place. I do not like dark matter and dark energy things. Thank you all.
kadir
