How to Solve a Doppler Effect Problem with a Moving Vehicle and Siren at Rest
The discussion focuses on solving a Doppler Effect problem involving a moving vehicle and a stationary siren. The initial calculation of wavelength using the formula wavelength = velocity/frequency is questioned due to the vehicle's motion. It is suggested that the problem may have missing information, specifically the vehicle's speed and the emitted frequency. To address the issue, using a variable to represent the unknown speed of the vehicle is recommended for a more accurate solution. The conversation emphasizes the importance of correctly interpreting the problem setup to find a valid answer.
jariz
Two students (A and B) hear a siren from an emergency vehicle, heading East along Rivers St with a speed of 10.0 kHz. Student A is standing still on the sidewalk, while Student B is jogging West, with a speed of 6.20 m/s. The vehicle starts 300 m away from the students and continues past them, for the purposes of this problem.
Find the frequencies heard by Student A, As the vehicle approaches the student.
When the vehicle and student are side-by-side.
As the vehicle moves away from the student.
Repeat the above items for Student B.
I believe I could figure this out fairly easily if I could just get the velocity of the emergency vehicle. I have never seen the speed represented in kHz and as I don't know the wavelength, I don't know how to calculate velocity from velocity = wavelength*frequency. Maybe I'm going about this all wrong, but I'm struggling just to get started on this problem. Any help at all would be appreciated.
Wavelength = velocity/frequency. Speed of sound = 343 m/s.
Pretending the siren is at rest in air:
Wavelength = velocity/frequence --> (343 m/s) / 10,000 Hz = .0343m.
I don't believe this is the correct way to go about solving the problem, since the vehicle is moving at the start and the siren is not at rest.
Yeah, that's an error. I suspect the original sentence said the emitted frequency was 10.0 kHz and that it also gave a speed. Something got accidentally deleted.
About all you can do, barring a correction from the teacher, is use a variable ##v## to represent the (unknown) speed of the vehicle and then solve the problem in terms of ##v##.
Likes jariz
