Doppler effect, source and receiver in different media
To calculate the frequency of a sound wave received by a helicopter from a submarine, one must consider the Doppler effect while accounting for the change in wave speed as the sound transitions between water and air. The frequency emitted by the submarine remains constant, but the speed of sound differs in each medium, affecting the observed frequency. The Doppler shift formulas can still be applied by using the appropriate speed of sound for each medium when calculating the frequency. It is essential to apply the correct parameters for both the submarine and helicopter's motion relative to the sound wave. Understanding these principles allows for accurate frequency calculations despite the change in media.
nikolafmf
Hello,
For convenience, we can say that a submarine at some depth in sea emits sound wave which refracts from the surface of the sea and is caught by a helicopter at some height above the sea. If we know the speeds of the submarine and the helicopter and the frequency of the emitted wave (and, of course, the speed of the sound in water and air), how are we going to calculate the frequency of the received wave? I know how to use the Doppler shift's formulas when the wave travels all the time in a same media. But, when it changes media, it also changes its speed. How can we account for that?
Nikola
Frequency is not afected by passing between media.
Yes, I know that. But in the formula for Doppler effect, wave speed occurs, as in the first formula here: http://en.wikipedia.org/wiki/Doppler_effect#General. And speed do changes by passing between media. So, how can I calculate received frequency?
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
