Doppler effect wavelength from car
The discussion revolves around a problem involving the Doppler effect, specifically focusing on a car traveling at a certain speed with a siren emitting sound waves. Participants are tasked with finding the wavelength of the sound waves in different positions relative to the car and the frequency perceived by a stationary observer.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the Doppler effect and the relevant equations, with some questioning the definitions of variables in the provided formula. There are attempts to calculate the wavelength based on the car's speed and the frequency of the siren, as well as discussions on how to approach the problem of finding the frequency heard by a stationary observer.
Some participants have made attempts to calculate the wavelengths for sound waves in front of and behind the car, using equations from their textbooks. There is an ongoing exploration of how to derive the frequency from the calculated wavelengths, but no consensus has been reached on the overall approach or final answers.
Participants note uncertainty regarding the definitions of variables in the equations and the implications of the car's motion on the sound waves. There is also mention of the need to clarify the velocity of sound in the medium and how it relates to the source's velocity.
matt_crouch
A car is traveling at 30m/s in still air. the frequency of the siren on the car is 600hz. The velocity of sound in still air is 330 m/s. what is the wavelength of the sound waves
a)directly in front of the car
b)directly behind the car
What is the frequency of the sound heard by a stationary observer
c)directly in front of the car
d)directly behind the car
FD=CD/Cs *Fs
Im not really sure where to start if someone could point me in the right direction.
Cheers
FD=CD/Cs *Fs
Cheers
OK, let's kick this off. Can you first get the frequency of the doppler shifted sound wave? I think your equation above (though you haven't defined what each variable represents) should tell you that.
Also, write out how to get your C's.
well i can find the wavelength of the car but i think its only when its stationary I am not sure
If Cs of the source is 30 m/s an the frequency is 600 hz
then the wavelength is
0.05 m
but I am not so sure where to go from there.. if i have Cs and Fs how do i find what the wavelength in front and behind is
actually i think i have the answer.. i used an equation that was stated in my textbook..
Wavelength behind = (vm+us)/Fs
where Vm= velocity of sound in medium
Us= velocity of source
and it gets an answer of 0.6 m
and
wavelength infront = (vm-us)/Fs
given an answer of 0.5 m
and from here i can calculate the frequency of each wavelength from V= F*(Lambda)
and
Awesome! Have a good one.
