Double Delta Function Potential
jhosamelly
I have
V (x) = \sqrt{((h-bar ^{2})V_{0})/2m} [\delta(x-a)+ \delta(x+a)]
How do I find R and T?
Under what condition is there resonant transmission?
How did you solve the 1 delta function potential? Do something similar here.
well, Yes I have the solution for that but I don't understand it that much. Please help. Thanks
So, for the scattering states, you can assume plane waves. You can, for example, have an incident plane wave from the left, and then you can have waves going in both directions in the middle and on the right. And then you would need to match boundary conditions.
ok. I got these answers. Are these correct? Someone please tell me.
General Equations
U_{I} = e^{ikx} + R e^{-ikx}
U_{II} = A e^{ikx} + B e^{-ikx}
U_{III} =T e^{-ikx}
Boundary Conditions
if a = 0
U_{I} = U_{II}
1 + R = A + B
U_{II} = U_{III}
A + B = T
discontinuity equation
U'_{I} - U'_{II} = - \sqrt{\frac{2m V_{o}}{h-bar^{2}}} U_{a}
ik (1 - R) - ik (A - B) = - \sqrt{\frac{2m V_{o}}{h-bar^{2}}} R
U'_{II} - U'_{III} = - \sqrt{\frac{2m V_{o}}{h-bar^{2}}}U_{a}
ik (A-B) - ikT = - \sqrt{\frac{2m V_{o}}{h-bar^{2}}} T
/// i hope someone can tell me if these are correct so I can continue my calculations. Thanks.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
