Double Integral Homework: Evaluate & Change Order if Necessary
  • Thread starter Thread starter cse63146
    Integral
The discussion revolves around evaluating a double integral and the potential need to change the order of integration. The integral in question involves a function with sine and cosine components, and participants are exploring the implications of their calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to evaluate the double integral and expresses confusion regarding a mistake in their calculations. They also inquire about the appropriate timing for changing the order of integration.
Participants are actively engaging with the original poster's calculations, providing hints and clarifications regarding the integration process. There is a focus on understanding the implications of the limits of integration and when it may be beneficial to change the order.
There is mention of a lack of coverage on changing the order of integration in class, which may influence the original poster's understanding and approach to the problem.
cse63146
Evaluate the following double integral. Change order of integration if necessary.
\int^{1}_{0} \int^{x}_{0} x^2 sin(\Pi x y) dy dx
\int^{1}_{0} \int^{x}_{0} x^2 sin(\Pi x y) dy dx = -\frac{1}{\Pi}\int^{1}_{0} x cos(\Pi x^2 ) dx
Let u = x^2 and du = 2x dx
- \frac{1}{2 \Pi} \int^{1}_{0} cos (\Pi u) du = -\frac{1}{2 \Pi} \frac{sin (\Pi x^2 )}{\Pi} |^{1}_{0} = - \frac{sin( \Pi)}{2 \Pi^2} = 0
but that's wrong. Anyone catch my mistake?
I was also wondering when I'm supposed to change the order of integration. Thanks.
Hint: What is the value of \cos(0)?
cos(0) = 1
I see what you meant, let me try it
I was referring to when you integrated the sine with respect to y, and received a cosine. The lower integration limit is 0 so it cos(0) should not vanish.
Edit: I see you discovered what I meant. It took 20+ minutes for this computer to load my reply!
AssyriaQ said:
I was referring to when you integrated the sine with respect to y, and receive a cosine. The lower integration limit is 0 so it cos(0) should not vanish.
Took me a little while, but I got it. Thank you.
I was just wondering when the right time to change the order of integration is, since we never covered it in class.
When it is convenient. Certainly if you can't do a double integral in a given order you should try changing the order.
That certainly makes sense. Thank You.
  • · Replies 19 ·
  • · Replies 105 ·
