Drag force on cylinder in parallel flow
A correlation for the drag force on a cylinder in parallel creeping flow is sought, with the user noting that their length-to-width ratio allows for the assumption of an infinitely long cylinder. The discussion highlights the challenge posed by Stokes' paradox, which is relevant for flow perpendicular to the cylinder but also affects parallel flow due to the influence of inertial forces at larger distances. Solutions from Batchelor and Keller using slender-body theory are mentioned as useful, with the latter providing results applicable to finite cylinders. Lamb's hydrodynamics solution is recognized as not being exact, as it also incorporates a linear inertia term in the Navier-Stokes equations. Overall, the conversation emphasizes the need for a straightforward equation for calculations without delving deeply into complex derivations.
MichielM
Hi,
I'm looking for a correlation of the drag force on a cylinder in parallel creeping (stokes') flow (i.e. the flow is alongside the axis of the cylinder). My length-to-width ratio is such that assuming an infinitely long cylinder is perfectly okay.
Does anyone know where I can find such a correlation?
I've tried deriving it myself but I ran into something called the Stokes' paradox. I know this can be solved by an approximation method (taking a linear inertia term into account), but I do not want to dive in that deep, I just need the equation for a calculation.
I've found useful equations from Batchelor (1970) and Keller (1976) who use 'slender-body theory' in which the rod is approximated as a line of stokeslets (singular force terms)
Are you asking if the flow is parallel to or or perpendicular to the axis of the cylinder?
Stokes' paradox is, IIRC, for flow perpendicular to the axis of the cylinder. There's an exact solution in Lamb's 'hydrodynamics', which is at work. It involves the Euler constant (0.577...).
Stokes' paradox was first found for a cylinder perpendicular to the flow, but the same effect (and for the same reason) is present for flow parallel to the cylinder. The basic problem is not the direction of flow but rather the fact the effect of inertial as compared to viscous forces are no longer negligible at large distances from the body.
As for the flow solution: slender body theory provides results for both parallel and perpendicular flow for finite cylinders. Lamb's solution is for an infinite cylinder. Although I said that would be perfectly fine given my length to width ratio, the results for slender body theory apply to finite cylinders which is more useful to me. Moreover, lamb's solution is not exact either, it also involves assuming a linear inertia term in the navier stokes equation
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 28 ·
21K
  • · Replies 45 ·
