Δt=6.7 s, Δx= .25 miles what is speed?
  • Thread starter Thread starter burton95
    Speed
The discussion focuses on calculating the speed of a dragster that travels 0.25 miles in 6.7 seconds under constant acceleration. The relevant equations include v = vo + at and x = xo + ½at². The average speed was calculated as approximately 134.33 mph, but the final speed requires determining acceleration first. The consensus is that since the dragster starts from rest, the equation simplifies to x = ½at², allowing for the calculation of acceleration and final speed without needing to convert miles to meters.
  • Understanding of constant acceleration equations
  • Familiarity with basic physics concepts such as velocity and acceleration
  • Ability to perform unit conversions (miles to hours)
  • Knowledge of average velocity calculations
  • Study the derivation and application of the equation x = ½at²
  • Learn how to calculate final velocity from average velocity in constant acceleration scenarios
  • Explore the implications of starting from rest in kinematic equations
  • Investigate unit conversion techniques for speed and distance measurements
Students studying physics, particularly those focusing on kinematics and constant acceleration problems, as well as educators looking for examples of practical applications of these concepts.
burton95
A dragster starts from rest and travels 0.25 miles in 6.7 s. Assuming that the acceleration is constant, what is its speed (in miles per hour) at this point?
Δt= 6.7 s
Δx= .25 miles
Constant acceleration equations
v = vo + at
x = xo + vo t + ½ a t2
xo + ½ (v + vo) t
2 a (x - xo)= v2 - vo2
all of the relevant constant acceleration equations I have in front of me have too many variables to isolate one given this. I know I can figure Vavg .25/0.00186111 hrs (6.7 s.) = 134.3284 but this doesn't do me any good. If you could nudge me in the right direction I would appreciate it.
There are only 2 things you don't know here, the acceleration and the final speed. All other things you do know. As the problem says the body starts moving from rest, so there's v0. Aside from that, you now it travels a distance of .25 miles, which all you need to now, simply define x0=0 which means Δx=x, and that's all. You should be able to solve the problem.
You need to convert miles to meters. Then you'll get acceleration using x = ½at^2 (it starts from rest so v0=0). Vfinal=at
so in Δr = vΔt + (1/2)a(Δt)2 the vis v0? This was not clear. Thanks
Yes. Since the car starts from rest, the equation simplifies to x = ½at^2.
Yes, in that equation, the v is the inicial velocity of the body, usually named v0.
Actually, you don't have to convert miles to meters.
Also, if the acceleration is constant, then the average velocity is half the final velocity. The OP already calculated the average velocity. So...
Chet
13K
