Dual Slit Experiment: Detecting Photons/Particles?
jimcave
hello - I wonder has anyone tried to place a detector for (photons/particles) just as they leave the emitter. If so does the wave like behaviour disappear?
At the emitter or source does not make a diff.
But there are many ways to detect "which way" or which slit and all remove the wave like interferance. Do a search here on "double slit" or "Erasure".
Yes, RandallB is right, because a detector at the emitter really just turns that into the source. If you still have the same experiment with the source at that point, then you'll still get the same experimental result. If you move the detector closer to one of the slits, then you are in effect doing the experiment with the source at that point, and when you fail to illuminate the other slit with that source, then you will lose your interference pattern.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
