- 21
Suppose it’s nearing the end of the semester and you’re taking n courses, each with a final project that still has to be done. Each project will be graded on the following scale: It will be assigned an integer number on a scale of 1 to g > 1, higher numbers being better grades. Your goal, of course, is to maximize your average grade on the n projects. You have a total of H > n hours in which to work on the n projects cumulatively, and you want to decide how to divide up this time. For simplicity, assume H is a positive integer, and you’ll spend an integer number of hours on each project. To figure out how best to divide up yourtime, you’vecome up with a set of functions{fi :i=1,2,...,n}(rough estimates, of course) for each of your n courses; if you spend h≤H hours on the project for course i, you’ll get a grade of f_i(h). (You may assume that the functions f_i are nondecreasing: if h' < h, then f_i(h')≤f_i(h).) So the problem is: Given these functions{f_i}, decide how many hours to spend on each project (in integer values only) so that your average grade, as computed according to the fi, is as large as possible. In order to be efficient, the running time of your algorithm should be polynomial in n, g, and H; none of these quantities should appear as an exponent in your running time.
I am pretty sure that I have to use the knapsack problem. In this case, it is a little bit different because in the knapsack problem each element is unique and have a different weight and different value. In this case the weight is the time that you spend in each class and the value your grade. I don't know how to apply the knapsack in this case hence we have to choose the f_i(h) for each h and i.
