Dynamics assignment, power output of car
The discussion revolves around a Mechanical Engineering assignment focused on calculating the power output of a Vauxhall Corsa engine and related dynamics. Participants explore the calculations required for both braking distance and energy dissipation, as well as engine power output based on given parameters.
  • Homework-related
  • One participant describes their struggle with the assignment, particularly with part 2 regarding engine power output calculations.
  • Another participant requests the original calculations to assist in checking for errors.
  • A participant realizes they misinterpreted the air:fuel ratio as a volume ratio instead of a mass ratio and details their calculation process for engine power output.
  • Concerns are raised about the robustness of the calculated power output (160 bhp) being high for the engine size, with reference to typical outputs for similar engines (90-100 bhp).
  • Participants discuss the importance of considering the pressure drop at the inlet and the correct units for the calorific value of the fuel, noting potential errors in the original calculations.
  • One participant recalculates the power output considering the pressure drop and arrives at a figure of approximately 71.98 bhp, questioning its reasonableness.
Participants express differing views on the accuracy of the calculations and the interpretation of units. There is no consensus on the final power output figure, with some participants suggesting it seems reasonable while others highlight potential errors in the original approach.
Participants note limitations regarding the interpretation of the calorific value units and the impact of the pressure drop on calculations. There is also uncertainty about the exact model of the engine and its rated output figures.
Students studying mechanical engineering, particularly those working on assignments related to dynamics and engine performance calculations.
JamesB93
I'm currently studying Mechanical Engineering at Level 3 in the UK and I'm beginning my integrated masters in September. I've missed a large chunk of my studies this year due to a broken collarbone I sustained earlier in the year. Instead of getting any special dispensation I'm trying to work my way through my assignments now despite having very little lesson time.
I'm working through my Mechanical Principles: Dynamics assignment now and I've hit a wall on a question and just can't figure out how to advance.
The question word for word is:
Part 1:
A Manual 5-speed Vauxhall Corsa 1.4 16v with an all-up mass of 1,260kg is used to drive up a hill with an incline of 10% at 65km/hour.
If the driver applies the brakes as if undertaking an emergency stop and slows the car down to 30km/hour in 2.5 seconds, calculate the distance traveled under braking and the energy dissipated in each of the 4 brakes if the front:rear braking effort is split 60:40. Ignore all friction and aerodynamic losses.
If the driver now coasts up the hill until the car comes to a rest, calculate, ignoring losses due to friction and aerodynamics, the additional distance traveled and the potential energy increase whilst coasting.
Part 2:
The engine has a bore of 77.6mm and a stroke of 73.4mm. If the volumetric efficiency is 44% and the pressure drop at the inlet is 55% of atmospheric pressure at an engine speed of 6,000rpm, calculate the power output at the flywheel when the calorific value of the fuel is 47,850kJ/kg.K. Take atmospheric pressure as 1.01 bar, ambient temperature as 20C and the mass air/fuel ratio as 14.7:1/
If the car is driven at an engine speed of 6,000rpm in 3rd gear with a gear ratio of 1.41:1 with a final drive gear ratio of 3.94:1. calculate the driveline torques at the output of the gearbox if the efficiency of the gearbox is 97% and the final drive efficiency is 89%.
Now I think I'm fine on part 1, I seemed to do all the calculations there with relative ease, but on part 2 I've completely hit a brick wall, if someone could take me through the correct method of calculating the answers without giving me the answers I'd greatly appreciate it. My first attempt at calculating this indicated that this 1.4 litre Vauxhall was outputting 6,350bhp and using 168 litres of fuel a second so I know I'm going insanely wrong somewhere.
This is my first forum post so if I've misplaced my post or broken any rules please let me know (but don't tell me off :().
We'd like to help you check your calculations, but you have neglected to post them. :sorry:
I seem to have had a clarifying moment, I was taking the air:fuel ratio for volume, not mass.
I did ((pi*bore2)/4)*stroke to get the swept volume of each cylinder. I then multiplied that by 4 to get the total swept volume of the engine and divided it by 2 because the pistons only intake air on every other engine revolution. I then multiplied this by the engine's volumetric efficiency to get the actual air intake per revolution. I then multiplied this by the revs per minute and divided it by 60 to get the air intake per second. I looked online and found a mass/m3 value of 1.2kg/m3 for air at 1.01bar and 20C. I multiplied the air intake per second by 1.2 to get the mass of air per second, then divided it by 14.7 to get the intake of fuel in kg/second. I multiplied this by the calorific value of the fuel and multiplied it by 1000 to get the power output of the car in watts and converted that to bhp by dividing it by 745.7 to give me a power output of approx 160bhp.
I'm a little worried that I didn't use the value of 55% pressure drop at the inlet and and didn't account for the value for what I assume is temperature in the calorific value of the fuel.
160 bhp is a pretty robust output for an engine of this size without a turbocharger.
Checking rated output figures online for this model engine shows an output of about 90-100 bhp. It's not clear what the exact model engine is being used in this car, but these output figures seem to be fairly constant for several different models. The outputs are quoted at slightly lower RPMs than 6000 as specified by the problem statement.
http://en.wikipedia.org/wiki/GM_Family_1_engine
There seems to be a mistake in the units of the calorific value of the fuel. The correct units should be kJ / kg.
Given the comments above, this is perhaps a reason that the pressure drop at the engine air intake should be taken into account.
Those are my (very) rough notes on the engine power output so far. Apologies for the handwriting, combination of dyslexia and recovering collarbone.
As I said previously, the calorific value of the fuel is in kJ/kg.K and I haven't accounted for the K on the end of that and I haven't accounted for the "pressure drop at the inlet of 55% of atmospheric pressure". Which both worry me. Can anyone see where I'd factor those in without getting a number for horsepower that's in the thousands.
Your image didn't upload correctly. :frown:
As I said in my previous post, the problem statement seems to be using incorrect units for the calorific value of the fuel. The correct units should be kJ / kg (No K).
Okay if I account for the pressure drop and use it to alter the mass of the air as it enters the engine, then follow on with those numbers I get 71.98 horsepower.
Checking online I can see that the maximum output of one the 1.4 litre Vauxhall Corsa 5 speed manuals are in the range 85-100. I'll query with my lecturer on the units for calorific value, maybe he's gotten confused with specific heat capacity there.
Do you think 71.98bhp seems a reasonable answer to this?
Thanks for all the help, you're a life saver.
It seems like a reasonable figure.
  • · Replies 102 ·
  • · Replies 31 ·
  • · Replies 26 ·
23K
