Dynamics Polar Coordinates question
23 replies · 6K views
Marchese_alex
Hi everyone. I am a little desperated cause my exam is on monday and still much stuff to do.
I don't get when I am supposed to use/consider radial and tranversal forces. Most excercises say "it rotates on the horizontal or vertical" I guess this is the info that tells me if there is radial/tranversal forces but i don't get it. Some time they consider the forces and sometimes they dont. I attach an example
Ps. Please keep it simple cause the profesor isn't that good and basically I am learning by my self
Thanks!
Welcome to PF!
Hi Marchese_alex! Welcome to PF! :smile:
Usually, you have an F = ma equation for each,
but one of them involves an unknown force …
in that case, you have to use the other one!​
in this case, the only radial force is the spring (because there's no friction), and you know what that is, so you can use the radial equation
you can't use the tangential equation because you don't know what the tangential force is (until you work it out from the radial equation!) :wink:
What I've gather from internet(because my profesor never teach us this) is like you say... i will have two forces radial (Fr=ma) in the direction of "r" (according to book) and angular force, that will be tangential to the path or just perpendicular to Fr (Fbeta=ma) correct me if wrong. If i see that the object angel changes I say that there's an angular force. For example, if the rod goes from horizontal (flat on floor) to vertical, i can say that a angular force is present. Correct?
And since there's a change in angle it will be going in a circular motion, and if there's a circular motion I have a centripetal force. Is that is the same thing as radial force or is the samething as radial aceleration(Ar)--> Fr=mAr
correct, but confusing :confused:
there are two F = ma equations, one radial and one tangential
(essentially, there's only one F = ma vector equation, of which you can take the components in any two independent directions, which you usually take to be perpendicular)​
there may be two forces, or more than two forces, it's the number of equations that matters
if the angel o:) accelerates then yes, there must be a force in the tangential direction
(but if the angle changes uniformly, no)
correct :smile:
(even if the angle changes uniformly)
except you really ought to call it centripetal acceleration, and not mention centripetal force unless you're using a rotating frame of reference
if there is angular motion, then there is always a centripetal acceleration
this is separate from the radial acceleration, which is d2r/dt2
you must subtract the centripetal acceleration (because it's always negative :wink:) from the radial acceleration to get the total "a" to put in the radial F = ma :smile:
to illustrate the last point, try this problem
a smooth rod rotates uniformly and horizontally with angular velocity ω
a bead is free to slide (without friction) on the rod … obviously, it will move away from the centre!
but the only force on it (there's no spring or anything else) is the normal force from the rod, which is tangential
so why does it have a radial motion, and what is the equation? :smile:
[/QUOTE]
When you say substract centripetal acceleration you mean ~~> see part III picture
Is my diagram correct? Is radial force(Fr) always in that direction?
http://i174.photobucket.com/albums/w105/marchese_alexander/cd953eb0b2ce1c91d11cce442007042f.jpg
yes, the radial component of acceleration is always ar = r'' - r(θ')2 :smile:
r'' is what i call the radial acceleration (i don't know whether other people call it that, or whether they call the whole of ar the radial acceleration)
and r(θ')2 is the centripetal acceleration
there isn't necessarily a radial force
for example, if a weight on a string attached to the ceiling moves in a horizontal circle, the only forces are vertical (the weight) and along the string (the tension) …
but the radial direction is horizontal :wink:
What exactly make this excercises different that they say Fr exist?
no, they don't call it the radial force, they call it the radial component of the force :wink:
the (net) force always has a radial component,
but there isn't always an individual force along the radial direction :smile:
and since there angular motion I will have centripetal acceleration. Right?
Ok i get the centri acceleration. Now i just don't get
1.the radial and tranversal component part of a force... Is it radial for "x" component and tranversal for y
2.what exactly is F and Fr representing in the free body diagram
Right! :smile:
In the diagram, "F" seems to be a mistake for "Fθ".
The problem asks for the "radial and transverse components of the force exerted on A", which are Fr and Fθ.
Radial is the r component, and transverse is the θ component.
(tangential isn't often used, it's the component of the force along the line of motion, which won't be transverse unless r is constant)
tiny-tim said:
Right! :smile:
Got it!
How about this exercise.
The only part I don't get is why I can't say that the first derivative of the angle is 0 and they put that is w(angular velocity). I know that the first derivative is angular velocity and the second derivative is angular acceleration. Also I know if I say is 0 then I would not be able to find what the exercise is asking. I am just trying to understand the "why".
Heres my data http://i174.photobucket.com/albums/w105/marchese_alexander/5ce37c38be157e984f3f113fe1a3a65f.jpg
Marchese_alex said:
… why I can't say that the first derivative of the angle is 0 and they put that is w(angular velocity).
θ' is the angular velocity, ω (same as x' is the ordinary velocity, v)
i don't understand why you think ω = 0 :confused:
if it's moving, then its speed isn't 0, and its angular speed isn't 0
Ok! Thanks
Marchese_alex said:
Why in excercice ( 14.94) its wrong to say Fr-mgsin(angle)=m(bla bla) and rigth to say Fr=m(bla bla). Or symply put why the weight is not being considered?
Whats the difference in this excercice ( 14.96) that they consider "mg"
14.94 is in the x-y plane (ie horizontal) :wink:
What do you mean? Still dumb lol
The #95 #97 (can see in pictures) they don't say anything about x,y plane and they put it the same way
14.96 obviously includes gravity, from the main diagram
the others don't mention gravity (and 14.95 makes it clear that the plane is horizontal, and asks for the horizontal force)
thats what I don't understand, when you say horizontal. What does horizontal mean? What information it let's me know?
do you mean that in a plane the W is not considered and at horizontal (no plane) it is concidered
no, they're the same … if the problem is purely horizontal, then gravity isn't considered either
(i wouldn't worry … exam questions are very clearly worded, even if book examples sometimes aren't :smile:)
