Dynamics trajectory motion help
To determine the speed of a car at point A in a projectile motion scenario, the car must cover a horizontal distance of 180 feet while transitioning from ramp A to landing at point B. The problem involves calculating the initial speed using the intersection of the car's parabolic trajectory and a straight line defined by the angle β, which has a slope of tan(30°). The horizontal motion remains constant while the vertical motion is influenced by gravity, with an acceleration of 32.2 ft/sec². The key equations of motion under constant acceleration should be applied to solve for the initial speed at point A. Understanding these dynamics is crucial for accurately solving the problem.
UCF_Martin
"In a movie scene involving a car chase, a car goes over the top of ramp A and lands a B below. Determine the speed of the car at A if the car is to cover distance d=180ft for \alpha =15° and \beta = 30°. Neglect aerodynamic effects.
Word.doc is the problem picture.
I have calculated the distance the car moves the in X, and falls in the Y. But other than that I am rather lost mathematically.
The hint for the problem states: "The required initial speed can be found from the intersection of the parabolic trajectory and the straight line whose slope in determined by tanβ"
Only problem is I have no idea as to what line tanβ is the slope of.
Hi UCF_Martin,
As the car becomes airborne at point A, two things happen: (i) it continues to travel horizontally with the same horizontal component of speed as it had at point A, and (ii) its vertical motion is controlled by gravity.
You should be able to quote in your sleep a set of equations describing motion under a constant acceleration (g = 32.2 ft/sec).
14K
