E=MC2 vs. m² = E² - p²: Motion vs Rest
genome66
Okay, so I know that E=MC2, is an equation in regards to an object at rest. But I recently came across another formula: m² = E² - p²; in the description, it stated, that it was basically E=MC2, in regards to an object in motion. Is this information valid?
Well, p is momentum, which is mv. E=MC² is for an object at rest only. It's not counting kinetic energy ½Mv², for example. For a massless particle, you don't have M at all, and the only thing you measure against is p.
But the equation is valid, right?
m^2=E^2-p^2 is generally valid, regardless of whether or not m is zero and whether or not the particle is moving. In the case of p=0, i.e., a particle at rest, you get m=E, which is simply the famous E=mc^2 expressed in units where c=1.
Yes it is valid. Although what you see written down is in a set of units where the speed of light is set equal to 1. The equation with SI units is E^2 = P^2c^2 + m^2c^4 where P = \gamma mv is the relativistic momentum, not just the ordinary momentum you see typically as just mv.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
