Earth as a giant sphere of electric charge
The discussion centers on the concept of Earth as a neutral body that can absorb charge from other objects. When a charged object contacts Earth, it neutralizes its charge because the vast size of Earth means its charge density remains unchanged. The Earth can absorb both positive and negative charges without needing to have an opposite charge itself. The movement of charges occurs due to repulsion among like charges, allowing excess charges from the smaller object to disperse into the Earth. Overall, the interaction illustrates how Earth's neutrality allows it to effectively neutralize the charge of smaller, charged objects.
jackson6612
I'm not a science student. So, I humbly request you to limit yourself to the basics, please do not indulge in infighting. If you ignore the request, you would be investing your efforts at the wrong place and perhaps it would be considered a pretentious show of knowledge.
If a gold leaf electroscope is connected to earth, there is no deflection, Earth is a neutral object. Then, how come whenever any charged object or electricity connection comes in contact with it, it absorbs all of the charge to neutralize the charge?
Please help me with it. Thanks.
The Earth is very big. Charge from charged object to Earth has essentially no effect on the charge density of the earth, while reducing the charge density to zero of the object in question.
This would not happen if the other (charged) object were as large as the earth. In this case (making suitable symmetry assumptions), if it were brought in contact with the earth, only half of its charge would migrate to the earth. The Earth and the object would both end up "half charged."
Thanks, Mathman.
Then, it should carry an opposite charge in order to absorb the charge of other polarity, but how can it because it is considered a neutral body? It can absorb both kinds of charge. I don't understand it. Perhaps, some example could be helpful.
Please remember I'm not a science student. Thanks.
I'm not a physicist, yet.
However, have you ever considered that perhaps the Earth is not neutrally charged? If the exact composition of the Earth is taken into consideration (By composition i mean, the X/100 of separate elements) and the sum charge associated with each X/100 (be they negative or positive), then it may be that the cumulative charge is different than neutrality.
It would make sense then that the greater negative charge of Earth would absorb any lesser positive charge of an object whose charge was not equivalent to Earths negative charge.
I like to look at it as magnets, just considering the strength of the north and south poles attraction. IF the poles had similar strength, then when their opposite poles were aligned, they would automatically neutralize the other. If one of the magnets had greater strength at its poles than the other magnet, then the weaker magnet would automatically be neutralized when it came into contact with the larger magnet. However, the charge of the greater magnet would not lessen or increase.
Just a guess, I may be incorrect.
jackson6612 said:
Then, it [the earth] should carry an opposite charge in order to absorb the charge of other polarity, but how can it because it is considered a neutral body?
The Earth doesn't need to be (say) positively charged in order to receive negative charge from a negatively charged object in contact with it.
The negative charges on the other object already repel each other. Before you put the object in contact with the earth, they don't have any place else to go, so they stay on the other object. Put the other object in contact with the earth, and they do have someplace to go. The negative charges that move from the object to the earth, do so because they are repelled by the negative charge that stays behind on the object.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
