Will a Large Body on Earth's Surface Pull a Smaller Body Towards Itself?
In summary, the conversation discusses the relationship between normal reaction and the force of Earth pulling a body, as well as the potential for a larger body to pull a smaller body horizontally. It is determined that for the larger body to pull the smaller one, it must have a much greater mass than Earth's mass. The shifting of the centre of mass is also taken into consideration.
mkbh_10
222
We know that N = mg , where N is normal reaction and mg is the force with which Earth is pulling a body . Now if i place another body ,lets say 10 ^12 kgs at a distance of 1 m from the body , will the larger body pull the smaller body horizontally towards itself , both these bodies are in contact with the surface of Earth , not joined to surface. will friction come into play in opposing the attraction towards each other ??
Now the problem i am facing is that when the larger body rests on the surface, it automatically becomes part of (earth+body) which is a composite system and 10^12 < < 10^24(mass of Earth ) so the smaller body won't experience any pull unless the mass becomes comparable to the order of Earth's mass and if we have a very dense body , 10^12 kg packed in a meter then it will pull the smaller body with a force of 6.7 m/s^2 which is comparable to 9.8 of Earth .
Also it must be that for the larger body to pull smaller one it shud have mass much greater than Earth to overcome Earth's gravity
As soon as you put another large mass into the system, you have to consider the shifting of the centre of mass. The Earth will exert a pull on this body and this body will exert a force of attraction on the earth. The centre of mass will shift according to the mass of this new body in space and the mass of the earth. so the small mass will shift towards the common centre of mass.
and pull the smaller one towards it.
Firstly, it is important to clarify that the equation N = mg is only applicable in situations where the object is at rest on a flat surface. In this scenario, the normal reaction force (N) is equal and opposite to the force of gravity (mg) acting on the object.
In the given scenario, if we place another body of 10^12 kg at a distance of 1 m from the first body, there will be a gravitational force of attraction between the two bodies. This force will be given by the equation F = GmM/r^2, where G is the universal gravitational constant, m and M are the masses of the two bodies, and r is the distance between them.
However, since both bodies are in contact with the surface of Earth and not joined to it, the normal reaction force will also come into play. This force will act in the opposite direction to the gravitational force between the two bodies.
As for the question of friction, it will depend on the coefficient of friction between the two bodies and the surface they are in contact with. If the coefficient of friction is high enough, it can oppose the gravitational force and prevent the two bodies from moving towards each other.
Moreover, as you have mentioned, for the larger body to pull the smaller body towards it, it would need to have a mass much greater than Earth's mass. This is because Earth's gravity is much stronger compared to the gravitational force between two relatively smaller objects.
Overall, the scenario described raises interesting questions about the role of gravity and normal reaction forces in a composite system. It also highlights the importance of considering all the relevant forces and factors when analyzing a physical problem.
1. What is the Earth Gravitation problem?
The Earth Gravitation problem refers to the scientific inquiry into the force of attraction between objects due to their mass. This force is known as gravity and is responsible for the motion of objects on the surface of the Earth and in our solar system.
2. How is the force of gravity calculated?
The force of gravity is calculated using Newton's law of universal gravitation, which states that the force between two objects is directly proportional to their masses and inversely proportional to the square of the distance between them. This can be represented by the equation F = G(m1m2)/r^2, where G is the gravitational constant, m1 and m2 are the masses of the objects, and r is the distance between them.
3. How does the Earth's gravity affect objects on its surface?
The Earth's gravity affects objects on its surface by pulling them towards its center. This is why objects fall towards the ground when dropped. The strength of the gravitational force depends on the mass of the object and the distance from the Earth's center. This is why larger objects, such as buildings or mountains, have a greater gravitational pull than smaller objects.
4. How does the Earth's gravity affect the motion of objects in space?
The Earth's gravity affects the motion of objects in space by keeping them in orbit around the Earth. This is due to the balance between the gravitational force and the object's velocity, which causes it to continuously fall towards the Earth while also moving forward at a constant speed. This is known as a centripetal force and is what keeps planets in orbit around the sun as well.
5. Can the Earth's gravity change over time?
Yes, the Earth's gravity can change over time due to various factors such as changes in the distribution of mass on the Earth's surface or changes in its rotation. However, these changes are minimal and do not significantly affect the force of gravity that we experience on a daily basis.
  • Science Fiction and Fantasy Media
  • Astronomy and Astrophysics
  • Other Physics Topics
