phymatter
- 131
if the Earth stops rotating , what will happen to the apparent value of g on its surface ?
Drakkith said:The force of gravity would be unaffected I believe. Without the rotation you might be able to measure a slightly higher amount of G on stationary objects on the ground since the surface isn't rotating anymore, but the amount would probably be negligible.
The Earth's rotation affects g in two ways. Directly, g includes a centrifugal acceleration term. This will vanish should the Earth stop rotating, thereby increasing the apparent value of g except at the poles. Indirectly, the Earth's rotation makes the Earth have a shape of an oblate spheroid. The Earth would presumably relax to a spherical shape should the Earth stop rotating. This would bring equatorial regions closer to the center of the Earth but make polar regions move further from the center of the Earth.phymatter said:if the Earth stops rotating , what will happen to the apparent value of g on its surface ?
