Is There a Faster Way to Factor Than Just Guessing Factors?
  • Thread starter Thread starter Tyrion101
    Factoring
To factor a quadratic equation like x^2 - 23x + 2050, one can derive a regular quadratic equation by substituting b with -23-a, leading to a product of 2050. However, the specific problem mentioned does not have real number solutions. Understanding prime factors can expedite the factoring process, as knowing small primes helps identify composite numbers. A prime factorization approach, such as checking for divisibility up to the square root of the number, is effective. Ultimately, while guessing can be tedious, employing mathematical strategies can yield faster results.
Tyrion101
One of my quadratic formula problems required me to factor so that the product of 2050s factors added to -23, that may not be exact, but I basically asked for a new problem since it was just practice, after an hour of getting close but never the right answer, and I was wondering, other than just using the computer program I wrote (which would likely be cheating) is there anything that gets me an answer faster than just guessing factors?
Mathematics news on Phys.org
So you were supposed to find numbers a,b such that their product is 2050 and their sum is -23? That is not possible (at least not with real numbers).
Anyway, I would do it like that:
As a+b=-23, we can write b=-23-a.
Plug this into a*b=2050 and you get a regular quadratic equation. With the numbers in your post, it does not have solutions, but with other numbers it has.
You had something like x^2 - 23x + 2050?
2050
2 - 1025
5 - 205
5 - 41
41 - 0
2050 is 2.5^2.41
Knowing the small primes helps. For example, I knew that 41 is prime. But also, there is an easy way to check. If a number n is composite, it has a prime factor ≤ ##\sqrt{n}##. So with 41, if it is composite, it has a prime factor < 7, so check 2,3,5, none divides it, so it is prime.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
