What Does \rightarrow Mean in an Equation?
  • Thread starter aricho
In summary, the symbol \rightarrow in an equation represents implication or conditional, and can be used in a logical context to represent a truth function. In the context of a limit, \rightarrow can be read as "approaches" and indicates the limit of a function as its input approaches a certain value, such as infinity. This concept is a fundamental part of calculus, where we can calculate something with increasing accuracy but can never determine the exact value.
aricho
71
sorry, this might seem like a stupid question for all you, but I'm only in year 10.
When you this symbol [tex]\rightarrow[/tex] in the middle of an equation, what does it mean?
Thanks
Mathematics news on Phys.org
What type of equation? In a logical context, [tex]\rightarrow[/tex] is the implication (or conditional) symbol, representing the truth function
[tex]\begin{array}{|c|c|c|}\hline P&Q& P\rightarrow Q\\ \hline T&T&T \\ \hline T&F&F \\ \hline F&T&T \\ \hline F&F&T \\ \hline \end{array}[/tex].
Are you seeing it used in this way? Ex. P -> Q?
i saw it under "lim" and it was pointing to infinity...what does it mean there?
cool, cheers...
Say you had something like
[tex]e=\lim_{n\rightarrow\infty}(1+\frac{1}{n})^n[/tex]
that mean if you chose any positive real number x
[tex]|e-(1+\frac{1}{n})^n|<x[/tex]
for all n>N(x)
That is to say loosely [tex](1+\frac{1}{n})^n[/tex] can be made as close as desired by chosing n sufficiently large.
You can imagine a function above and one below [tex](1+\frac{1}{n})^n[/tex] that represent respectively the largest and smallest values the function takes for all values greater than itself. The upper and lower functions become ever closer, meaning the function becomes confined to ever smaller intervals containing e as n becomes ever larger.
wow...i'm totally lost...sorry, could u explain that?...thanks... :bugeye: :confused:
e is a number that appears a lot in math. For example as the base of the natural log.
It can be shown that
[tex](1+\frac{1}{n})^n<(1+\frac{1}{n})^{n+1}[/tex]
also
it can be shown that there difference is less than e/n
and we know e is between the numbers
thus if we want to know e with in 1% we can take n=100 for example.
As we take n larger and larger we can trap it in smaller and smaller ranges.
We can then know it with more and more accuracy.
All of calculus is based on this type of situation. We know how to calculate something with more and more accurate approximations, but we can not calculate it exactly.
Here are some numbers to hopefully make it more clear
for each n we can generate a range for e with the above formula. As n becomes larger the range becomes smaller.
n=1 2<e<4
n=5 4.48832<e<2.985984
n=10 2.593742<e<2.853117
n=100 2.704813<e<2.7318619
n=1000 2.716923<e<2.7196408
n=10^6 2.718280<e<2.7182831
n=10^9 2.718281827<e<2.718281829
The actual value of e to 14 decimal places is 2.71828182846459
Remember that since e is irrational it has an infinite number of digits with no repeating digit patterns.
all this means that we can write
and when we do so what we mean is
can be made as close to e as we want by making n big enough
or conversley that if n is large it will be close to e and as n becomes larger it will become closer.
got it :approve: thanks for that...
What does → mean in an equation?
The symbol → is called a "right arrow" and is commonly used in equations to represent a relationship or operation between two values. It is read as "leads to" or "results in".
How is → used in math?
In math, → is used to show the direction of a relationship between two values. It can represent addition, subtraction, multiplication, division, or any other mathematical operation.
What is the difference between → and = in an equation?
The symbol → represents a transformation or relationship between two values, while = represents an equality between two values. In other words, → shows how one value affects or changes another, while = shows that two values are equivalent.
Can → be used in place of = in an equation?
No, → and = have different meanings in an equation and are not interchangeable. However, some equations may use both symbols to show both a relationship and an equality.
Are there any other symbols that mean the same as → in an equation?
Yes, there are other symbols that can be used to represent a relationship or operation in an equation, such as ->, =>, =>>, and =>>. However, → is the most commonly used symbol for this purpose.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
