Eddy Current Braking: Answers to Common Questions
Eddy current braking operates by inducing currents in a conductive plate as it moves through a magnetic field, which generates opposing forces according to Lenz's law. This opposition to motion results in a loss of kinetic energy, primarily due to resistive losses that convert energy into heat. The discussion clarifies that while resistive losses are significant, the opposing forces created by the eddy currents also contribute to the braking effect, similar to kinetic friction. Understanding the direction of the eddy currents is essential, as it explains the nature of the forces at play. Overall, both resistive heating and the magnetic interactions are crucial for comprehending how eddy current braking slows down motion effectively.
Fointy
Hello all :)
I'm doing some coursework on eddy current braking atm and I just need to clarify that I have the right idea about how the concept works.
Right, I know that when a conductive plate passes through the poles of a magnet, the change in magnetic flux induces eddy currents in the conductor. And that these travel in loops defined by Lenz's law so that the eddies will swirl in a way so that their own magnetic field is opposed to the change in flux that caused them.
But what exactly causes the loss of speed of the plate?
I understand that the eddy currents will come across some resistance and so some energy will be dissipated as heat. But is that it? What's the deal with the Lenz's law thing then... I mean, why is that important that we know which way the electrons loop, if all that matters is that the currents dissipate energy through resistive losses and this is equal to the kinetic energy lost?
Am I at all right in thinking that because the eddy currents loop in a way to oppose the change in flux, that there is some sort of magnetic repulsion/attraction thing going on? Such as,the front is attracted back to the magnet and at the back it is repelled by the magnet? And these combined cause it to slow aswell?
That was my initial thought but all I've ever found about it is talk of lenz's law and then resistive losses and I can't find any places to confirm or reject my confusion. Any help would be very gratefully received.
thank you
If you try to visualize eddy currents, you will probably go nuts. The bottom line is that eddy currents generated by the motion of metal plates, rolling metal wheels etc. in magnetic fields is that the induced eddy currents will always act in such a way as to produce forces and torques to oppose that motion. In that regard they are like kinetic friction. Yes, the slowing down of the motion is due to resistive losses. Heat generated by Ohmic losses is the exact equivalent of the heat generated by frictional forces.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
