Effect of air pressure on temperature
The discussion revolves around the relationship between air pressure and temperature in a hypothetical closed box with heat sources. Participants explore how the introduction of heat affects air pressure and temperature dynamics, particularly focusing on the behavior of warm and cold air in the context of convection and pressure equalization.
  • Charlie proposes a scenario where two heat sources are present in a closed box and questions whether increased air pressure in the upper half would prevent warm air from rising from the bottom.
  • Some participants argue that pressure equalizes throughout the box, suggesting that the warm air rises due to density differences rather than pressure differences.
  • There is a discussion about whether temperature equalization occurs alongside pressure equalization, with some suggesting that cold and warm air can remain separated due to natural convection.
  • One participant emphasizes that cold air is denser than warm air and questions whether this density difference could prevent warm air from rising, while others clarify that air behaves as a fluid and that buoyancy plays a role in convection.
  • Another participant notes that while pressure increases with temperature, it does not lead to localized pressure increases but rather an average increase throughout the box.
  • There is a contention regarding the role of temperature versus pressure in causing stratification within the box, with some asserting that temperature is the primary factor.
Participants express differing views on the relationship between air pressure and temperature, particularly regarding the mechanisms of convection and the behavior of air parcels. No consensus is reached on these points, and multiple competing views remain throughout the discussion.
Participants highlight the complexity of air behavior under varying temperature and pressure conditions, noting that assumptions about air being homogeneous or the effects of density may not fully capture the dynamics at play.
chas209365
Hello,
I'm posting here in an attempt to solve a practical problem involving air temperature and pressure in a home, but I'll pose the problem in a simple, hypothetical model.
Take a large, closed box with a certain quantity of air contained within. A source of heat is placed on the bottom half of the box. It heats up the air temperature, the air pressure increases, and warm air rises towards the top of the box.
My question is this: If you placed a second heat source in the upper half of the box, and made that heat source equal to or warmer than the heat source at the bottom of the box, would the increased pressure of the air in the upper half of the box prevent the warm air at the bottom of the box from rising, thereby increasing air temperature and pressure in the bottom of the box?
Thanks for any help on this basic question.
Regards,
Charlie Cavanaugh
Science news on Phys.org
Welcome to PF.
No, nothing constrains the pressure from equalizing throughout the box, so it equalizes throughout the box.
The warm air rises not because of the pressure difference (which is negligible) but because of the density difference.
russ_watters said:
Welcome to PF.
True this is more of a chemical thing than a physics thing the law that describes this do you know it OP?
Clue: air pressure/temperature and temperature and its relation to pressure.
Thanks for your quick replies.
russ: If the pressure equalizes throughout the box, would that mean that the temperature would equalize also? I'm a little puzzled by your comment about density difference being the key factor in making warm air rise. From my understanding, cold air is denser than warm air because of decreased molecular motion. Wouldn't a substance of greater density actually prevent a substance of lesser density from moving into the space it occupies? So if density was the key factor, wouldn't cold air in the upper layers of the box actually prevent warm air from rising into its space?
Charlie
Charlie
Cold air doesn't rise or fall any more than warm air does. It just moves between a gradient of pressure related to temperature.
I Think you are thinking in terms of absolutes, or that air is a homogeneous entity.
The pressure would go up due to the increased temperature. The higher temperature the higher the pressure, it is a direct correlation (correct me if I'm inaccurate).
The increased temperature would be because of you putting another heat source on the limited volume of the box. Thus an increased pressure in the box.
What is not going to happen is an increased pressure on a certain area of the box; but an increased AVERAGE pressure in the whole box.
No, cold and warm air can stay somewhat separated, mixing much slower, through natural convection. If the warm air starts on top, though, convection doesn't work and the air parcels can stay pretty well separated for a long time.
Cold air is denser because molecular motion keeps the molecules further apart.
No - air is a fluid, not a solid. One parcel of air cannot prevent another parcel of air from pushing it around.
No - what actually happens is the more dense air doesn't have the buoyancy required to stay aloft and so it falls. That's convection.
That is not correct. The pressure gradients in a room of 4m cubed will measurable only with an accurate barometer (and still inseparable from the atmospheric pressure gradient), but the temperature gradient could be pretty large - 10C or more between the floor and ceiling. No, it is temperature, not pressure, that causes stratification.
Correct.
  • · Replies 16 ·
