Effect of pressure due to change in diameter of pipe
In a comparison of two piping systems, a 4-inch pipe and a 2-inch pipe connected via a reducer, the pressure at the end of the 2-inch pipe will be higher than that at the end of the 4-inch pipe when maintaining the same flow rate. This is due to the increased pressure required at the pump discharge for the smaller diameter pipe to achieve the same flow rate. The pressure difference arises from factors such as head loss and the effects of contraction in the smaller pipe. Each piping system has a distinct pressure versus discharge relationship, which cannot be independently adjusted. Ultimately, the design and diameter of the pipe significantly influence the pressure dynamics within the system.
Nitheeswar
The pump has an outlet size of 4 inch
1) In case 1, 4 inch pipe is connected at length of 20 m
2) In case 2, 2 inch pipe is connected using reducer
In both cases the pump outlet conditions are same( having same flow rate at a given pressure)
What happens to pressure at the end of the pipe in case 2?
At which end of the pipe?
False.
All other things the same between the two systems:
If system2 is 20 ft. of 2 inch pipe (horizontal) and you want flow ##Q## out of it, it requires a certain pressure at the pump discharge ##P_2##.
If system1 is 20 ft. of 4 inch pipe (horizontal) and you want flow ##Q## out of it, it requires a certain pressure at the pump discharge ##P_1##, where ##P_1< P_2##.
In other words you need an effectively different pumps to achieve the flow rate in each system. Meaning impeller changes, speed changes, etc...
If you are running a positive displacement pump( aka constant volume pump) the flow rate will be equal, but not at the same pressure. The pressure adjust to whatever the systems demands at a flow with those pumps. Their pump curve is a vertical line at a fixed speed.
Isn't it one out of two: either the flow rate is the same OR the pressure is the same ?
And: doesn't it matter what's at the end of the pipe ? Atmospheric pressure, something else ?
Is this pressure difference only due to contraction and head loss in 2 inch (compared to 3 inch)?
This is a duplicated thread.
By mistake, it is uploaded 2 times.please delete it
Is this pressure difference only due to contraction and head loss in 2 inch (compared to 4 inch)?
Each piping system has its own pressure vs discharge relationship. They are not independently adjustable. It would also have to do with kinetic head consideration, not just head loss.
  • · Replies 38 ·
  • · Replies 31 ·
