Effect of wheel diameter in a car
  • Context: Automotive
  • Thread starter Thread starter rambharath94
    Car Diameter Wheel
The discussion focuses on the impact of wheel diameter on a car's performance parameters, specifically speed, torque, and handling. A larger wheel diameter increases the combined weight of the wheel and tire, affecting inertia and acceleration. For instance, a Porsche 911 typically uses an 18-inch wheel diameter for optimal performance, while Formula 1 cars utilize smaller wheels with stiffer sidewalls. Additionally, changes in wheel diameter influence tire stiffness and rigidity, which can affect handling and braking efficiency.
  • Understanding of vehicle dynamics and performance parameters
  • Familiarity with tire and wheel specifications
  • Knowledge of rotational inertia and its effects on acceleration
  • Basic principles of tire stiffness and rigidity
  • Research the effects of wheel diameter on vehicle acceleration and braking performance
  • Explore calculations for rotational inertia of wheel/tire assemblies
  • Learn about the relationship between tire stiffness and handling characteristics
  • Investigate the role of beadlocks in high-performance tire applications
Automotive engineers, performance car enthusiasts, and anyone interested in optimizing vehicle dynamics and handling through wheel and tire specifications.
rambharath94
Hello guys
I want to know how the wheel diameter of car affects the car's performance parameters(physical significance) such as
1)speed
2)torque
3)handling.
I would also appreciate if some equations are used to substantiate the physical understanding of these.
Just to make sure, are you referring to the wheel diameter or tire diameter ?
Steering wheel or wheel for the tires?
Thanks for replying . i actually mean the rim diameter
wheel for the tyres.
Assuming the wheel material is denser than the rubber in a tire, then a larger wheel increases the combined weight of wheel and tire. Assuming a fixed outer diameter of a tire, the side walls can be either too tall or too short for optimal handling, depending on how stiff the sidewalls are. As an example, in the case of a car like a Porsche 911, a wheel diameter around 18 inches is usually optimum for racing tires, while a Formula 1 car uses a smaller wheel, and relatively taller and stiffer sidewalls.
The following assumes the tire diameter stays constant.
Inertia:
By modifying the wheel diameter, you will modify the total inertia of the wheel/tire assembly, thus affecting the acceleration of the vehicle.
It may increase or decrease, depending on the shape and design of the wheel. Here is a calculator to get a crude evaluation for rotational inertia of wheel/tire.
Tire stiffness:
With a small wheel diameter, the vertical stiffness of the tire usually increases. This means that the tire radius will vary more under vertical load (such as weight transfer) (deflection = load / stiffness). This affects the force and speed measured at the contact patch (force = torque / radius; speed = rpm * radius).
The preceding is also true for braking, which will affect http://www.jakelatham.com/radical/info/brake_calculators.shtml.
Having a higher tire vertical stiffness also means that the tire can loose contact more easily with the road - if it is relatively too rough - hence affecting handling.
Similarly, the longitudinal stiffness will most likely decrease with smaller wheel diameter. This means that a very large acceleration/braking force can be absorbed, giving a smoother force transfer to the ground, like on drag tire for example:
Tire rigidity:
Having a smaller wheel diameter means a less rigid tire. This means that it is easier to remove the tire from the wheel under a lateral force, i.e. under lateral acceleration; A beadlock is then necessary.
A more rigid tire usually also means lower rolling resistance.
Also, as the wheel diameter increases (no matter the tire diameter), the force between the rim and the tire increases, which can lead to slipping; Again, a beadlock may be necessary.
Finally, a larger wheel usually means more space for a larger brake system which can absorb more heat.
we had a great discussion on mech engineering post
Alloy wheels and fuel economy
by Dr Lots-o'watts
use search above to check it out..
  • · Replies 22 ·
  • · Replies 20 ·
