Effective resistance between two points using symmetry
35 replies · 5K views · last reply
Point D and C are equipotrntial so you can remove wire DC and see how the circuit look like
Sent from my Mi A1 using Tapatalk
Jahnavi said:
Thanks for replying .
This is exactly what I would like to understand [emoji2] .
Please assume this is a 2D circuit .
If I draw a line perpendicular to AB , the left and right parts are mirror image , this make points D and C symmetric . But symmetric points do not necessarily have to be equipotential . Right ?
How can then we argue that points C and D are equipotential .
Path symmetry indicates that D and C are equipotential
Jahnavi said:
Thanks !
Hello again,
I kept quiet because I was obviously making it worse for you in your frustration -- but I couldn't think of a good way to help you out without giving it all away. The picture I had in mind was, of course
Circuit schematic with nodes A (top left) and B (bottom left). A 2 Ω resistor connects A to B directly. A middle branch has a 1 Ω resistor from A to node D and a 1 Ω resistor from D to B. A right branch has a 1 Ω resistor from A to node C and a 1 Ω resistor from C to B. A wire links D and C horizontally.
and once you have it in front of you like this, the path is clear (thanks to the fact that all four on the right have the same resistancce)
(note: in many cases you can't even get it as 'flat' as this and there are one or more crossovers left to make life edifficult)​
and now I have a question for you:
with hindsight, what would have been a good hint that could have helped you effectively at that point ? (after all, you will definitiely not be the last one to get stuck with a problem like this).and as a side note: you see that I don't agree with
ehild said:
The original circuit cannot be drawn in-plane
  • Circuit schematic with nodes A (top left) and B (bottom left). A 2 Ω resistor connects A to B directly. A middle branch has a 1 Ω resistor from A to node D and a 1 Ω resistor from D to B. A right branch has a 1 Ω resistor from A to node C and a 1 Ω resistor from C to B. A wire links D and C horizontally.
Hi BvU ,
Not hint , but if you could have been a little more expressive and had written - "Please try my suggestion and you would clearly see how the two points C and D are equipotential using the same technique (drawing a line perpendicular to AB) you are trying to employ in the OP " . That would have worked :smile:
AND you could have added a smiley in post#6 :wink: .
I was under the impression that you had overlooked my concern in the OP and were trying to suggest an alternative strategy to simplify the circuit .
By no means this is an excuse .I was clearly wrong in not working as per your suggestion .
But then , this is the limitation with any online platform . It doesn't precisely portray your thinking/feeling :smile: .
Thanks, will :smile: more often !
