Efficient Integration of x^5 exp(x^2) in First-Year Calculus
  • Thread starter Thread starter kingwinner
    Integrate
The discussion revolves around the integration of the function x^5 exp(x^2) within the context of first-year calculus. Participants are exploring various methods to approach this integral, particularly focusing on integration techniques.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants suggest using integration by parts, with different choices for u and dv being discussed. There is mention of a strategy to reduce the power of x through repeated integration by parts. Some participants also introduce the idea of tabular integration and substitutions to simplify the process.
The discussion is active, with various strategies being proposed. Some participants are questioning the necessity of multiple integrations by parts, while others are exploring alternative methods, such as substitutions. There is no explicit consensus on the best approach yet, but several productive lines of reasoning are being examined.
Participants note that the integral is related to a statistics problem involving the expectation of a gamma distribution, which raises questions about whether integration by parts can be avoided. There is also a mention of the need for familiarity with integration techniques, indicating varying levels of experience among participants.
kingwinner
I am losing my first year calculus skills :(
I don't remember how to integrate x5 exp(x2).
What is the fastest way?
N/A
Maybe we need to integrate by parts? But how should I set u and dv?
Thanks for any help!
I would go with integration by parts. There are various possibilities for u and dv, but the one I would try first is u = x4, dv = xex2dx. A good strategy for integration by parts is to choose dv so that it is the most complicated thing that you can actually integrate.
The goal is to get an integral with x to a power less than 5, and keep applying integration by parts until you get a fairly simple integral, like [tex]\int xe^{x^2}dx[/tex], which can be done by an ordinary substitution.
If you are familiar with the trick of tabular integration for integration by parts, you can use the substitution u=x², du=2xdx, to get the solution faster without having to perform multiple integrations by parts.
How many times do I have to integrate by parts?
Depending on the substitution used, at least 2 times.
This integral actually occurs in the middle of a statistics problem. If I know the expectation of a gamma distribution, can I possibly avoid integrating by parts in the above integral? If so, how?
I don't know anything about that. You posed the problem, and you have gotten a couple of strategies for solving it. If you don't know how to do integration by parts, say so, and we'll help you out.
Another method that works here is to substitute u=x^2 ...
This will work for the integral of x^n exp(x^2) when n is odd.
  • · Replies 18 ·
  • · Replies 44 ·
