pyroknife
- 611
- 4
The discussion revolves around the concept of eigenfunctions and eigenvalues in the context of a linear differential operator T acting on functions f(x). Participants are exploring how to determine if a given function is an eigenfunction by applying the operator and analyzing the resulting expressions.
There is an ongoing exploration of the relationship between k and the corresponding eigenvalues. Some participants have provided insights into the nature of the eigenvalues and how they relate to the values of k, while others are questioning their understanding of the definitions involved. The discussion is active, with multiple interpretations being considered.
Participants are navigating the definitions of eigenfunctions and eigenvalues as they relate to the operator T, with some confusion regarding the implications of their calculations. There is a mention of constraints related to the values of k and how they affect the eigenvalues.
pyroknife said:The problem is attached.
I am not quite sure how to do the 3 parts.
for part a:
Do I just plug in the f(x) equation into T(f)?
If so that gives me k2ekx-2*kekx-3ekx
I'm just not sure what I'm supposed to be doing.
klawlor419 said:For any value of k this is a well-defined function for the eigenvalue. Thus e^kx is an eigenfunction for all k.
hmmm, I wish setting lambda=0, which is incorrect.vela said:No, why would it? How are you going from ##\lambda = (k-3)(k+1)## to ##\lambda=3, -1##?
vela said:Remember k represents a specific value. For each possible value of k, ekx is an eigenfunction of T. For example, if k=2, then you have f(x)=e2x, and the corresponding eigenvalue is ##\lambda = 3##.
So what are the allowed values of k and what values of ##\lambda## do these correspond to? Hint: If you plotted ##\lambda## vs. k, what kind of curve would you get?
Oops, yes.pyroknife said:Did you mean lambda=-3?
I edited my previous post, and it probably answers your question now.I would be a parabolic curve. k can be all real #s as a previous user stated. Lambda would be all real #s. But I am unsure how I would describe lambda for each eigenfunction? Lambda is a parabolic function of all real k values.
vela said:Oops, yes.
