Eigenvalues and eigenvectors, pauli matrices
ma18
Look at the matrix:
A = sin t sin p s_x + sin t sin p s_y +cos t s_z
where s_i are the pauli matrices
a) Find the eigenvalues and normalized eigenvectors (are they orthogonal)?
b) Write the eigenvector of s_x with positive eigenvalue as a linear combination of the eigenvalues of A
I got an answer but I am not confident as to it's veracity.
The matrix A is :
(cos t , sin t cos p - i sin t sin p
sin t cos p + i sin t sin p, - cos t)
or
(cos t, sin t (e^-i p)
sin t (e^ip), - cos t)
Finding the eigenvalues
(cos t - lambda, sin t (e^i p)
sin t (e^i p), - cos t - lambda)
You get
lambda^2 - 1 = 0
So the eigenvalues are +-1
The problem is finding the eigenvectors;
For +1
(cos t - 1, sin t e^(-i p )
sin t e^i p, - cos t - 1)
Using the cofactor method you get the equations
(cos t - 1) x +(sin e^i p) y = 0
(sin t e^i p) x + (-cos t - 1) y = 0
I get
v1 = C_1 (-e^-i p tan (t/2), 1)
v2 = C_2 (-e^i p tan (t/2), 1)
Then normalizing
C_1 = 1/sqrt(e^-2 i p tan (t/2)^2 + 1)
C_2 = 1/sqrt(e^-2 i p cot (t/2)^2 + 1)
I don't know how to do b
Any help/checking would be helpful
For +1
Looks good so far. Try using the trig identities ##\sin^2 \frac \theta 2 = \frac{1 - \cos \theta}{2}## and ##\sin \theta = 2 \sin\frac \theta 2 \cos \frac \theta 2##. That'll make the algebra a bit easier to deal with.
Thanks for all your help guys!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
