Eigenvectors & subspace spanning
AngrySaki
The question is at the end of a chapter on spanning vector spaces.
Let P denote an invertible n x n matrix.
If \lambda is a number, show that
E_{\lambda}(PAP^{-1}) = \left\{PX | X\;is\;in\;E_{\lambda}(A)\right\}
for each n x n matrix A. [Here E_{\lambda}(A)} is the set of eigenvectors of A.]
I'm having trouble understanding what the equality means, or how to read it.
The left side looks to be the eigenvectors of a diagonal matrix, which I think are always the columns of an identity matrix.
On the right side, I assume the matrix P would be the eigenvectors of A, so I think it's the span of the products of P multiplied by each of it's columns.
I don't know what to make of those ideas, so I think I'm either missing something about eigenvectors or spanning (very possible), or reading the question wrong.
Thanks
The matrix PAP-1 is diagonal if the columns of P are the eigenvectors of A, but you don't know anything about P other than it's invertible.
Let B=PAP-1. What the question is asking you to show is that the eigenvectors of B are of the form Px and that Px is an eigenvector of B, where x is an eigenvector of A.
Thanks, that helps a lot.
Does this makes sense as an answer?
Eigenvalues of A can be written:
(\lambda I -A)X=0
So the right side of the original equation is:
P(\lambda I -A)X=0
Move the P inside:
(\lambda P -PA)X=0
Multiply by I:
(\lambda P -PA)P^{-1}PX=0
Move P inverse inside:
(\lambda PP^{-1} -PAP^{-1})PX=0
Eigenvalues of PAP-1 are of the form PX:
(\lambda I -PAP^{-1})PX=0
Except they're not eigenvalues, they're eigenvectors.
Oh, oops. I mean to write eigenvectors.
Just to be clear, does the method makes sense if I had written the word eigenvectors instead of eigenvalues?
(\lambda I -A)X=0
More correctly, "if X is an eigenvector of A, with eigenvalue \lambda, then
(\lambda I- A)X= 0"
P(\lambda I -A)X=0
Move the P inside:
(\lambda P -PA)X=0
Multiply by I:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
