How to Write (a_1+...+a_n)(b_1+...+b_n) in Einstein Notation?
The discussion focuses on expressing the product (a_1 + ... + a_n)(b_1 + ... + b_n) in Einstein notation. One participant suggests using the term I^{ij} = 1, while another argues for a simpler form using a (superscript i) * b (subscript i). The conversation highlights the need for clarity in index notation, noting that the original expression is not rotationally invariant, which complicates the use of the Kronecker delta or Levi-Civita symbol. Ultimately, the necessity of introducing I^{ij} is debated, emphasizing the importance of correctly representing combinations in Einstein notation. The thread concludes with a consensus on the complexity of the expression and the need for careful notation.
mnb96
Hi!
I want to write the following expression in Einstein notation:
(a_1+\ldots+a_n)(b_1+\ldots+b_n)
I tried it by introducing the term I^{ij}=1 and writing:
a_ib_jI^{ij}
Are you aware of another, more convenient form for this?
Mathematics news on Phys.org
According to the Einstein summation convention, when ever a expression contains one index as a superscript and the same index as a subscript a summation is implied over all values that the index can take. (As defined in Schutz "A First Course in General Relativity")
So what do you need the I super ij for?
I would just write it as
a (superscript i) * b (subscript i) for all values that i can take.
(My LaTex usage is horrible that is why I typed it out.)
Thanks
Matt
In general
(a_1+\ldots+a_n)(b_1+\ldots+b_n) \neq \sum_{i=1}^{n}a_i\,b_i
You probably read too fast: a^ib_i=a_1b_1+\ldots+ a_nb_n and that clearly does not produce all the combinations.
I'm trying to figure out if I really need to introduce that I^{ij}=1 term, or if I can express that by using the kronecker delta or the levi-civita symbol.
Yes, that is correct, but I said one is a superscript and one is a subscript. You have them written as both subscripts.
Yes, I did overlook the parenthesis.
Would it not then just be
a (superscript i) a (subscript i) * b (superscript 1) b (subscript i)
Thanks
Matt
Yes, thanks torquil.
Matt
The problem with this is that if you construct an expression out of a, b, the kronecker delta and/or the levi civita symbol, and it has no free indices, it will be rotationally invariant. Your original expression is not rotationally invariant, so you need something else, e.g. your matrix of 1's.
Torquil
