G_ab: Calculating a Corrected Value
  • Thread starter Thread starter Philosophaie
    Value
Philosophaie
G_ab = R_ab - 1/2 * R * g_ab
and
R = g^(ab) * R_ab
then
G_ab = R_ab - 1/2 * R_ab * (g^(ab) * g_ab)
=1/2 * R_ab
for this abomination someone please correct me.
No. a and b are free indices on the right, so a and b have to be free indices on right, i.e., they cannot be repeated and summed over.
Use R = g^{cd} R_{cd} instead of R = g^{ab} R_{ab}.
Also, what does g^{ab} g_{ab} equal?
g^(ab) * g_ab = I, the Identity Matrix only if a square matrix and when dotted with R_ab gives you back R_ab.
Philosophaie said:
g^(ab) * g_ab = I
No.
It is true that
g^{ab} g_{bc} = \delta^a_c.
Think about it some more.
That term doesn't appear in the equation. What you have is:
g^{cd} g_{ab}
Where the left metric tensor is contracted with the Ricci tensor. Remember not to repeat indices more than twice. It messes up the summation convention. Use different letters like George Jones said.
If you use the equation:
G_ab = R_ab - 1/2 * R _cd
You will get all the elements of the Ricci Tensor in each cell. Is really what the equation is?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
