Undergrad Rocket Fuel Ejection: Intuitive & Math Explained
  • Thread starter Thread starter fatpanda1
    Fuel Rocket
Ejecting fuel over time allows for more efficient acceleration of a rocket compared to an instantaneous fuel ejection, which can damage the rocket structure and payload. The Tsiolkovsky rocket equation indicates that the change in velocity (Δv) is dependent on the mass of the rocket and fuel, as well as the exhaust velocity, but does not explicitly factor in burn time. Instantaneous burns result in a sudden change in momentum, leading to less effective thrust as energy may be wasted on unburnt fuel. Additionally, shorter burns can lead to higher initial acceleration, but practical limits exist for structural integrity and component tolerance. Ultimately, the efficiency of fuel ejection is influenced by the context of the rocket's trajectory and the surrounding environment.
fatpanda1
TL;DR
Why does ejecting fuel over time cause rocket to go faster than ejecting all at once?
Can you give both intuitive and mathematical explanation please.
Likes Delta2 and Dale
Because if you eject it all at once it destroys the rocket structure, and the payload.
  • Haha
Likes Filip Larsen, russ_watters and Vanadium 50
In contexts or models where the rocket equation applies this is question is a bit misleading, so I am curious as to the context the question has been posed in? (There are quite common situations in the normal life of a launcher that is not modeled well by the rocket equation and which also gives a good answer to the question, but the question itself is just posed as if applicable to any situation which is not true).
fatpanda1 said:
Summary:: Why does ejecting fuel over time cause rocket to go faster than ejecting all at once?
Because ejecting the fuel all at once and having a single clump of exhaust gasses then travel at its normal exhaust velocity relative to the rocket is an incorrect expectation.
If you eject a huge blob of fuel from a tiny rocket at a particular exhaust velocity relative to the rocket, it takes only a small amount of energy. You might well think of it as ejecting a tiny rocket from a huge blob of fuel. You wind up with a huge unburnt blob of fuel.
Likes hutchphd
Amateur rockets come close. They expend their fuel in a small fraction of the flight duration.
Likes Vanadium 50 and PeroK
You don't want them to be really efficient.
You need them to be about a foot long +/- half an order of magnitude, so they can be easily built. You also don't want them flying more than a few hundred feet (say 500 feet +/- a half order of magnitude) because then recovery can prove difficult. So they need short burns.
Likes anorlunda
For the math, the Tsiolkovsky rocket equation is: $$\Delta v = v_e \ln \left( \frac{m_r + m_f}{m_r} \right)$$ where ##m_r## is the mass of the rocket without the fuel and ##m_f## is the mass of the fuel and ##v_e## is the exhaust velocity.
If you simply burn it all instantaneously then conservation of momentum gives $$\Delta v = v_e \frac{m_f}{m_r} $$
A series expansion of gives $$\ln \left( \frac{m_r+ m_f}{m_r} \right) \approx \frac{m_f}{m_r} - \frac{m_f^2}{2 m_r^2} + O(m_f^3)$$
So I get the opposite, that ejecting it all at once makes it go faster.
Likes Leo Liu and russ_watters
In addition to the better answers above, as you shorten the duration of the burn, you increase the acceleration for that initial period during the burn. Depending on the payload, there is a practical limit to how high the acceleration can be. Even without humans on board, the electronic assemblies and electro-mechanical components have limited tolerance for high accelerations...
Likes russ_watters
I don't understand this argument. The Tsiolkovsky equation does not contain the time you take to exhaust the fuel. So in this approximation it doesn't matter how quickly you exhaust the fule. The change in velocity is always the same. So why should your 2nd formula apply for exhausting the fuel instantaneously and why shouldn't then apply the Tsiolkovsky equation as well?
The derivation of the Tsiolkovsky equation works as follows: You assume an arbitrary exhaust ##\mu(t)## (exhausted mass of fuel per unit time). Then assuming the relative velocity ##v_f## of the fuel to the rocket being constant yields the momentum balance
$$\mathrm{d}_t (m v)=-\mu(v_f-v)=\dot{m} (v-v_g),$$
i.e.,
$$m \dot{v}=-\dot{m} v_g$$
or
$$m \frac{\mathrm{d} v}{\mathrm{d} m}=-v_f$$
from which by separation of of the variables the Tsiolkovsky equation follows.
The main oversimplication seems to be the assumption that ##v_f=\text{const}##.
Likes bob012345 and ergospherical
Faster acceleration means less thrust(percentagewise) wasted supporting the weight of the rocket(when launching vertically).
vanhees71 said:
I don't understand this argument. The Tiolkovsky equation does not contain the time you take to exhaust the fuel. So in this approximation it doesn't matter how quickly you exhaust the fule. The change in velocity is always the same. So why should your 2nd formula apply for exhausting the fuel instantaneously and why shouldn't then apply the Tsiolkovsky equation as well?
The 2nd formula is an instantaneous burn, meaning that all of the exhaust has the same final velocity. Even though the rocket equation doesn't explicitly contain the burn time, it is based on the assumption of a non-instantaneous flow, so the exhaust velocity varies as the rocket accelerates. So the final state in the two cases is different. I.e. in my formulation an instantaneous burn is not just a limiting case of a non-instantaneous burn with a very short burn time.
Hm, as I just added to my posting, the assumption underlying the Tsiolkovsky equation is ##v_f=\text{const}## (where ##v_f## is the velocity of the fuel relative to the rocket). If this is not the case you likely get a different result, but the standard Tsiolkovsky equation doesn't depend on the time needed to exhaust a given amount of fuel, ##\Delta m=m_{\text{ini}}-m_{\text{end}}##. You simply get
$$\Delta v=v_f \ln(m_{\text{ini}}/m_{\text{end}})=v_f \ln [(m_{\text{ini}}/(m_{\text{ini}}-\Delta m)],$$
as you stated yourself above.
Based on that expectation, burning all at once would give maximal final velocity? Because that would give the exhaust the maximal momentum in the opposite direction?
So the tiny rocket flies off before all fuel was burned, and the fuel energy goes into accelerating the exhaust in all directions, not just backwards?
My two cents - if a mass ##q## is ejected instantaneously at ##t=0##, i.e. ##m(t) = m(0) - q H(t)##, and at constant velocity ##v_e## relative to the rocket, then the differential equation describing the motion is\begin{align*}
m \dfrac{dv}{dt} = v_e q \delta(t)
\end{align*}where ##\delta(t)## is the Dirac delta. Thus the change in velocity is\begin{align*}
\int dv = v_e q \int \dfrac{\delta (t)}{m(t)} dt = \dfrac{v_e q}{m(0)}
\end{align*}where the integral is taken over any interval containing ##t=0##. (The value of ##m(0)## is that of the rocket plus the initial fuel).
[This result is slightly different from the expression for an instantaneous burn given by @Dale].
  • Wow
Likes Leo Liu, Dale and Delta2
Allow me to expand on my first reply above:
a) The ideal rocket equation indicates it doesn't matter how quickly you eject your propellant (as long as you do at same relative speed), the rocket will end up with the same total delta-V.
b) In situations where you have drag terms (i.e. atmosphere) for sections of the trajectory, maintaining a lower speed at those sections will (everything else being equal) give higher total delta-V. Add to this the practical limitation that even without atmosphere its not possible to enter a closed orbit around a planet from its surface using only one impulsive launch maneuver (but that only relates to the "shape" of the orbit, not the total speed).
c) For some orbital maneuvers the rocket will obtain the highest total delta-V if the maneuver is done impulsively (i.e. all at once) at the periapsis (see Olberth's effect for details).
So depending on the actual context the original question may be either misleading, true or false.
The really short answer:
fatpanda1 said:
... ejecting all at once?
Because this is better known as 'the rocket esploded'.
It is left as an exercise for the OP to determine why this is inefficient.
I think this is covered in reply #2
Likes DaveC426913
I actually scanned for such replies before posting. I guess I wasn't as diligent as I should have been.
Exactly. For an instantaneous burn the velocity of the fuel relative to the rocket is undefined since the velocity of the rocket is discontinuous (of course it is all well defined in the limit, but I am not assuming a limiting case). So for an instantaneous burn (the way I assumed) the ##v_e## is the velocity of the exhaust gas relative to the inertial frame in which the rocket was initially at rest.
Likes vanhees71
In some ways it's more natural to take ##v_e## as the relative velocity after the burn because it gives the correct limiting behaviour as per #14 i.e. ##m(0)v = (m(0)-q)(v+\Delta v) + q(v + \Delta v-v_e) \implies \Delta v = \dfrac{v_e q}{m(0)}##.
Likes Leo Liu, vanhees71, mfb and 1 other person
That is interesting. I hadn’t looked at that.
Likes vanhees71
This seems wrong since the rocket also 'instantaneously' accelerates to its final speed, so it should be viewed as a limit as the burn time decreases to zero, which seems to be the same transfer of momentum to the exhaust regardless of the rate of burn. No matter how short you reduce the burn time, the exhaust velocity never approaches the same value.
In other words, it seems that given X amount of fuel and M rocket mass, in deep space already, you get exactly the same final speed regardless of the rate of burn, which is why burn time doesn't appear in that rocket equation. So the reason for the chosen rate of burn has more to do with engine efficiency and getting off the planet and other considerations.
Burn too slow and too much of the energy is used just countering gravity (a problem only if your rocket is pointed up, hardly the most efficient orientation). A sufficiently low power rocket will never leave the pad at all, at least not until its weight drops below its thrust. Hence the need for high G force at takeoff, but not so high when say leaving Earth orbit.
Faster fuel expenditure means larger engines, and that adds mass to the engines and, as has been pointed out in prior posts, greater structural mass needed to withstand the greater forces involved. Burns also are throttled back at first to prevent excessive speed while still in dense atmosphere. You always hear them talk about throttling up after a minute or so. No need to hold back if there's no atmosphere with which to contend.
Slow expenditure of fuel is indicated when already in space, which is why ion engines are optimal when time is not of the essence. If there's people on board, there's the mass of the life support to think about. Get there faster just so you don't have to cart along so many resources to keep your perishable payload intact.
Likes Leo Liu, vanhees71, Filip Larsen and 1 other person
That is explicitly not what I assumed because then there is no difference. The OP can (should) clarify.
Nonetheless either approach is still valid, since as the burn time ##\delta t \rightarrow 0##, then mass ejected ##q \rightarrow 0## for any finite mass ejection rate ##r(t)## and the change in velocity given by the rocket equation\begin{align*}
v_e \ln \left( \dfrac{m(0)}{m(0)-q} \right) = - v_e \ln \left( 1 - \dfrac{q}{m(0)} \right) = \dfrac{v_e q}{m(0)} + O(q^2)
\end{align*}reduces to the formulae in #14 and #20. Clearly a mass ejection rate ##r(t)## which does not remain finite is unphysical.
Likes vanhees71
Unphysical, yes, but not nonsensical.
Dale said:
That is explicitly not what I assumed because then there is no difference. The OP can clarify.
One possible interpretation would be the limit of pulsing ##n## chunks each of mass ##\frac{m_\text{fuel}}{n}## and each at exhaust velocity ##v_e##. [Measuring exhaust velocity relative to the remaining payload velocity not relative to pre-burn craft velocity].
If you take the limit as n increases without bound, you wind up with the Tsiolkovsky equation. If you take the value for any finite n, including n=1 you get something less.
Taking the limit as a continuous mass flow rate increases without bound is silly because it's taking the limit of a constant.
Note that under this interpretation, we do not use all of the energy in the fuel. If we decide to use all of the energy in the fuel then the optimal (albeit impractical) approach is to burn it all at once and expel the payload like the bullet from a gun. Anything else leaves waste energy in the relative velocity of the scattering bits of exhaust gasses. You get delta v that scales with the square root of the fuel capacity rather than with the log of the fuel capacity.
Likes bob012345 and berkeman
I would say nonsensical too! That the mass ejection rate must vary only between finite limits (on physical grounds) guarantees that ##q \rightarrow 0## in the limit of an instantaneous burn, in which case the rocket equation reduces to the result of the collision problem.
Likes vanhees71
Yes -- if we were to harvest all of the energy in the fuel and eject it as a single lump.
The fuel energy goes -- somewhere. We do not care. The model just says we did not use it all. Maybe we are spraying unburnt fuel. Maybe the unburnt fuel burns and scatters. Whichever.
The collision problem is hardly non-sensical. Sorry, but I disagree.
ergospherical said:
The non-sensical part is to consider any mass ejection rate ##r(t)## which is unbounded. If one does so then I don't think it should be a surprise when discrepancies arise. :smile:
Unbounded mass ejection rates are perfectly physical.
You burn all of the fuel and package it up into a canister ready for expulsion. You harvest the energy and use it to propel the canister, ejecting it a single impulsive *whoomp*. That's an inelastic collision.
Even if you decide to take a slow motion video and decide that the ejection was not instantaneous, it is still most easily analyzed as if it were.
  • · Replies 47 ·
  • · Replies 41 ·
  • · Replies 55 ·
  • · Replies 27 ·
