Elastic Collision Momentum Question
The discussion revolves around an elastic collision problem involving two blocks, where the initial conditions have been altered by a teacher. Participants are exploring the implications of these changes on the outcome of the collision, particularly focusing on the velocities of the blocks post-collision and the concept of separation.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants are questioning how the change in initial velocity affects the nature of the collision, particularly whether it remains elastic or becomes inelastic. There is confusion about the implications of both blocks moving at the same velocity after the collision and the wording of the problem regarding separation.
The discussion is ongoing, with participants expressing confusion and seeking clarification on the problem's wording and physics. Some guidance has been offered regarding the interpretation of the problem, but no consensus has been reached on the implications of the collision type.
Participants note that the problem's wording may not align with the physics concepts being discussed, leading to misunderstandings. There is mention of previous test performance and the impact of the wording on problem-solving approaches.
s8on95
Same question as this link except my teacher changed the numbers. 1996-B No.1 part C
http://lodischool.tripod.com/dovesol/DOVE96SOL.pdf
Velocity of Bock A=4v0
2. mv+mv=mv+mv
3. I understand how to do the question in the pdf file. However, I don't understand how the concept applies in my teacher's version. Solving for the velocity you get 2.5 m/s which is supposed to be the answer. However, the question says "the objects separate after collision". Wouldn't they not separate if they both travel 2.5 m/s after the collision? I don't understand how this is possible.
Is the initial speed of block A the only thing the teacher changed? If so, then it is an inelastic collision.
So would this problem be "impossible" to do then? If block B continues at 2.5, then it'd be inelastic but it says they separate. (I got this problem "wrong" on a test btw)
Again, if the only thing the teacher changed is the initial velocity of block A from 3v0 to 4v0, then a speed of 2.5v0 for B implies a speed of 2.5v0 for A as well. You say you got that question wrong. Do you know what the right answers are?
I got the problem wrong because I made up random numbers. What I did was wrong. The right answer was that block A continued at a speed of 2.5 V0. My dilemma is that would this not imply an inelastic collision if they continued at equal velocities?
Nowhere in the problem was an elastic collision implied, either in the original, or the altered problem.
Sorry, wrong wording. I mean to ask how is it possible they can separate when they go at the same velocity after collision?
They haven't separated. You're getting too caught up on the wording and not on the physics.
The problem clearly says the blocks separate after collision in Part C.
Your teacher copied the problem and didn't change the wording. No physics has been changed. You are just obsessing with the wording of a badly worded problem.
But that is exactly my problem. Shouldn't it NOT BE POSSIBLE for the physics to be possible with the given wording? If I were given the same problem as the link, I could've done it with ease. I understand the physics concepts/math no problem. When I took the test though I just thought this was a weird scenario.
It is predicted an inelastic collision with 2.5 m/s of both of them together
What happens is they actually separate and still both go at 2.5 m/s?
During the test I calculated and was going to put 2.5 m/s but this would've implied they didn't separate. That is why I ended up becoming confused and doing a bunch of random weird stuff. I understand the mathematical physics but my problem is exactly with obsessing over the wording. It just shouldn't make sense!
I will state it again. THEY DID NOT SEPARATE. Your teacher changed the numbers but did not change the wording. This happens all the time, to the best and the worst teachers. The calculations you did show that it was going at 2.5v0 (not 2.5m/s, you were never given an actual speed), and I've shown you that your calculations are correct, so that is the speed it was moving with. If you had used 2.5m/s you would have gotten the question right. If you still have questions about the wording of the problem, you need to take it up with your teacher, not Physics Forums.
Okay then. I shall consult my teacher (another student did and I think she was said to respond with something along the lines of "they just separate"). Thanks for the help!
Let us know what your teacher says. I'm really curious.
  • · Replies 16 ·
